Random transmission parts | FerrariChat
Discussion in 'Mondial' started by Johno_888, Jun 26, 2021.
  1. Johno_888
    Johno_888 Rookie
    Aug 3, 2018
    15
    Cambridge Ontario
    Johnathan Stremi
    Hi all,
    This is for my 88 Mondial.
    My transmission gasket was leaking around the gasket so I decided it was time to change it.
    I found 3 springs a ball and an aluminum cylinder in the pan. All seem to be in good condition. The magnetic plug was pretty clean and I’m not really having any transmission issues other than it’s hard to put into second gear when cold.
    I have no idea where they came from. Any thoughts would be appreciated.
    Johnathan
  2. conan
    conan Formula Junior
    Nov 13, 2011
    389
    Ah, the famous detent balls. They came from the left hand side of the pan, in the gasket. Three balls, three springs and one cylinder.
  3. Johno_888
    Johno_888 Rookie
    Aug 3, 2018
    15
    Cambridge Ontario
    Johnathan Stremi
    Thanks for the quick response.
    Doesn’t sound to complicated. Do you know how they go back in?
  4. Steve Magnusson
    26,826
    #4 Steve Magnusson, Jun 26, 2021
    This photo describes where they go and how they are held in place by the pan itself:
    (One technique is to use/pack some grease in the holes to hold them in place before you bring up and install the pan. At the factory, the gearbox is inverted during assembly so gravity holds them in place before the pan is installed.)
    conan and afterburner like this.
  5. Johno_888
    Johno_888 Rookie
    Aug 3, 2018
    15
    Cambridge Ontario
    Johnathan Stremi
    Thank you. Sounds like I’m going to have a fun afternoon.
