Rapid left turn signal ('89 328 GTS) | FerrariChat
Discussion in '308/328' started by slong, Mar 7, 2006.
  1. slong
    slong Rookie
    Feb 14, 2004
    17
    When engaging the left turn signal, the signal-light (and blinker noise) is rapid (about twice as fast as the right turn signal)....I'm assuming this is a relay switch gone bad but can not locate the relay/fuse panel. On page 96 of the manual it shows the smaller fuse box...but for the life of me I can not find it in the car (I know were the larger fuse panel is located)...any help would be greatly appreciated. PS..."J" on pg 96 is the relay I'm looking to replace (is that correct, or should I be looking at something else?) thanks...Stephen
  2. BigHead
    BigHead Formula Junior
    Oct 31, 2003
    995
    Outside of Boston
    Dennis
    It's not a faulty relay. It just signals that one of your turn signal bulbs (on the left hand side) is out.
    vty,
    --Dennis
  3. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,599
    Gates Mills, Ohio
    Jon
    Yes - and I think all cars do that, to alert you to replace the bulb.
  4. Ciao Bello 348
    Ciao Bello 348 Formula 3
    Oct 3, 2005
    1,844
    The Garden State, US
    John C
    Safe bet. Replace the bulb.
  5. Gatorrari
    Gatorrari F1 World Champ
    16,464
    Georgia
    Jim Pernikoff
    Remember that in front there are two turn bulbs on each side. Only one has to fail for you to get the rapid signal.
  6. gmark340
    gmark340 Karting
    Sep 21, 2005
    55
    New Jersey
    Mark
    On the 348/Mondial T, how are the front bulbs accessed? I've changed the rear bulbs since they are easy to get at through the rear trunk of the Mondial. I take it that the front lenses don't pull out the front, even when the screws are out, at least mine don't. Trying to reach the bulb from behind did not present an obvious route. Can someone provide me with a clue?
