355 - Rationale behind NOT "throwing parts at it"? | Page 2 | FerrariChat
355 Rationale behind NOT "throwing parts at it"?
Discussion in '348/355' started by Uberpower, Feb 26, 2024.
  1. INRange
    INRange F1 World Champ
    12,893
    Virginia/Florida/Caymans
    JD
    Yup I would be making my own at those prices. That is just ridiculous. Even if the fittings were 24K gold those prices just don't make sense for crimped connectors. I'll bet they have a deal with Ferrari about replicating those pieces which is why they are priced the way they are.
    Uberpower likes this.
  2. sfcarguy
    sfcarguy Formula Junior
    537
    Earth
    That stinks. That’s definitely not the result other members have had.
  3. JoeCab
    JoeCab Formula Junior
    478
    Colorado
    Joe C
    They can be a weird company to deal with. Sometimes it seems like their US and UK divisions don't have any communication whatsoever : (
    Uberpower and sfcarguy like this.
  4. PaulK
    PaulK F1 Rookie
    4,813
    Michigan
    Paul
    Uberpower, MK355 and JLF like this.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    Here is my take.
    When it costs $500 to diagnose a fault in a $100 part, just change the part before you go down the diagnostic route.
    I never buy new oil lines. Even Daniel at Ricambi tells me to have them rebuilt. The rebuild cost is much more reasonable. I have a complete set of 355 oil hoses in inventory so that I don't have to wait 2 weeks.
    SDL and O2 sensors on a 355. These problems have been solved many times over. Find someone else.
    Ahh, SRI, the purveyor of $2,000 Junior Power pins, $500 silicone hose, and the anti-skip 355 timing belt device. FIND SOMEONE ELSE.
    GatedF355GTB, Uberpower and INRange like this.
  6. Uberpower
    Uberpower Formula 3
    1,116
    Okay, just a quick update. In sum, Dave / Jenny / Scuderia and I decided to part ways. I'll leave it at that, without the associated detail; suffice it to say that my philosophy and theirs differed mightily and our respective personalities did not do much to cover over our professional disagreement. As such, I moved the 355 F1 over to Blue Chip in Denver.
    First off, I was amazed at the level of detail for the Blue Chip initial diagnostic. The inspections are loaded into a software called TekMetric, which seems reasonably good and I've seen it in use at other shops. There is a bit to be desired regarding the way the software organizes information, especially if you are used to looking at a black and white piece of paper with line items and numbers on it, but I do like the way the software integrates photos of the parts that are being referenced by the techs.
    Just a quick recap before going into this:
    • Bought the 355 F1 in February 2023 from Ferrari of Washington after they completed the major / 30k. Mileage was around 68k at the time.
    • Drove it from VA to FL, performed reasonably well but would not properly downshift from 3rd to 1st when coming to a stop light. Contacted FoW and there was literally zero response (on the day of the sale!) I will never, ever recommend FoW to anyone, ever. Terrible customer service / aftercare.
    • Finally figured out how to properly drive the F1 after roughly 60-90 days of ownership (leave it in SPORT mode, shift manually, operate the accelerator as you would when shifting a 3 pedal car).
    • The check engine light would come on from time to time as explained earlier in the thread when the SDL would trigger.
    • Scuderia replaced a single O2 sensor. Didn't help. (this is what started this thread) They also said that they saw a "dealership shorting harness" plugged into the F1 ECU. They never said really what this was or why it was there.
    • Between the time I dropped it at Scuderia and the time I got it back (months) it developed a significant oil leak. I took it back to Scuderia and it was noted that two of the four oil lines were leaking and to have all four rebuilt and reinstalled.
    • Here's where the argument began to heat up. I wanted them to replace the lines with OEM parts and they said the lines would be better to be rebuilt. I asked which of the four lines specifically needed to be rebuilt (who doesn't like specificity) and they told me to "come pick up the car" and gave me a "free" quart of oil to keep it topped up until I could find a new shop. Wow. Okay.
    • Took it to Blue Chip and received the following diagnostic repairs needed as result from inspection:
      • Drivers Side Fog Light Inop
      • A/C working but weak, needs recharge
      • No coolant in the tank when cold
      • Low CCA for battery, replace
      • Front lid struts do not hold hood, replace
      • Driver rear wheel bearing has play, replace
      • Wheels have scratches and missing paint
      • Rear tires new but wrong size
      • Engine oil leaks from cam covers
      • F1 Actuator seeping
      • Exhaust Bypass Valve doesn't seem to be functioning "stuck open"
      • Oil tank to block and lower oil cooler lines are leaking "a lot"
      • Passenger tie rod end boot torn
      • Passenger side CV boot is torn
      • Engine mounts saggy and engine sitting low.
      • Coolant hoses are old and should be replaced, leaking coolant
      • Wheel lug shoulders are cracked, should be replaced
    • Wow. Now you can see why I am pissed about Ferrari of Washington. Who among us would do a full engine out service and not replace motor mounts among other things. When buying an FCar from a franchise dealership, one assumes most of the above would have at least been checked under their "inspection". Nope. I get that the car is a very old car at this point, but Ferrari N.A. should know that their franchisees are not reconditioning used Ferraris for resale in the manner that their customers expect. This repair bill is five figures after a single year of ownership, most of which seems to be pre-existing.
    • Okay, I now have a very, very thorough diagnostic from Blue Chip. All of which cost me literally ZERO dollars. They gave some additional detail too regarding condition of certain other cosmetic / structural aspects that I'll not comment on here because it's already a very long post. Suffice it to say, those should have been disclosed by FoW also.
    • Blue Chip cannot get the new oil lines, even though they are advertised on a few sites. So... they send them to Dave at Scuderia for rebuild, which they do successfully. I still haven't driven the car but Blue Chip assures me they are good to go. I bought used ones off of Ebay and had them rebuilt, so now I have my old leaky ones that I can also have rebuilt and keep as spares.
    • Replaced the leaking coolant lines, replaced coolant.
    • Remanufactured and replaced leaking oil lines, replaced oil.
    • Loose rear wheel bearing tightened, recommended to replace later.
    • Replaced Battery.
    • Replaced all 20 wheel shoulders and refinished wheels cosmetically.
    • Replaced front hood struts.
    • Replaced engine mounts.
    Will do the following myself:
    • Drivers Side Fog Light Inop (assuming this is a bulb or a harness)
    • Rear tires new but wrong size (will replace with correct size when wear is significant enough)
    Will defer the following until the winter (so I can drive for the summer months through October):
    • Driver rear wheel bearing has play, replace (will see how well the tightening worked)
    • Engine oil leaks from cam covers (these are minor, want to drive with remanufactured oil lines for a bit)
    • F1 Actuator seeping (again, minor- contacted GTE Engineering, great guys, may push to next winter based on convo)
    • Exhaust Bypass Valve doesn't seem to be functioning "stuck open" (this might be the reason for the CEL light, but not hurting anything)
    • Passenger tie rod end boot torn (evidently an issue because dirt can get in and make steering less precise)
    • Passenger side CV boot is torn (ditto)
    So, now I have a much more thorough picture of what needs to be done to the 355 and when. I also get zero questions about replacing a part when I say "just replace it". Given that the parts for these are more and more difficult to come by, it only gives me additional incentive to "throw parts at it" when it is not performing optimally, because someday there may not be any available parts to throw.
    My last thought is a stunning admission of ignorance that makes me laugh at myself a bit. When I sold my last F355 GTS (1996 3 pedal) back in 2007 (for a song to FoD, ugh) my brain froze in place the costs associated with the major service... and I've always thought of those as the "hard costs" associated with owning a 355. The most obvious faults with that line of reasoning is that: 1. In 2007 my 1996 F355 was still "only" 11 years old, and my 1999 355 F1 GTS is now an official "antique" at 25 years old. 2. Everything is far more expensive because of inflation (I'll keep politics out of it for purposes of this convo) including parts and labor.
    All of this makes for an ownership experience that is frighteningly expensive for those who do not turn their own wrenches, and as I do not plan to sell this car, I feel like I should go and educate myself about how to go about working on it properly. To do this, I'll need a properly outfitted garage and a significant amount of downtime... I probably will not have either of these in the next five years due to professional committments and the need to be somewhat mobile personally as a result. As such, I'll continue to rely on a series of independent shops including those such as Blue Chip (and yes, SR as a subcontractor to them) to keep my 355 on the road.
    Someday, I hope to have the highest mileage 355 in the world.
    Qavion and blox79 like this.
  7. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    Somebody on fchat told me once and it sticks: Nobody ever promised you owning a Ferrari was going to be cheap. That statement applies to all Ferrari, but specifically to the 355.
  8. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    Interesting. I didn’t even know there was a place for a shorting harness. Did the gearshifting improve after the plug removal and engine/gearbox(?) mount change?
  9. Uberpower
    Uberpower Formula 3
    1,116
    Agreed, though my opinion about buying from a franchised dealer stands. :)
    SR did take a few photos of it. I'll attach them here. I'm curious as to what your thoughts are.
    As for "running better without it" I asked them not to touch it as it was shifting fine after I "learned" how to drive it. I still haven't picked the 355 up yet from Blue Chip as the wheels are still being refinished and the new shoulders installed in them (shipping now). Should be end of next week or so if I can get it before my trip to CA, if not then I'll have to give the drivability update after I return on the 6th.
    Edit: Now that I think of it, the whole reason they went into the F1 ECU is because I bought the ScudIng Swiss eMT F1 relay and I wanted them to install it. The unit is still sitting in its box in my frunk.
    Qavion likes this.
  10. Qavion
    14,601
    Ian Riddell
    #35 Qavion, Jun 22, 2024
    Ah.. yes... I just found it in the wiring diagram. For a moment, I thought they had disconnected the 3 pin plug which connects the F1 TCU to the Motronic ECU. i.e. the CAN databus line.
    I don't know why they called it a shorting harness. It just looks like an extension for the diagnostic plug (assuming the wiring coming from the TCU is brown/red, black and grey/green).
  11. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,763
    It is an old car, things happen, things that may not even be FoW's fault or that they have any knowledge of.
    It was probably there to make the CEL go away--even with finally finding or fixing the problem(s)
    Can you even get OEM parts at this date ?? In any event I had some oil hoses rebuilt by the local aircraft maintenance facility at the local airport.
    Of the items on this list:: My F355 ahs seen 5,000 track miles and is nearing 70K total miles.
    4 batteries (minimum)
    7 axel boots
    5 Bearing hubs
    the lid struts have been dead for at least 15 years
    The ride heights can be adjusted to suit almost ANY tire SIZES that are reasonable
    Only *.gov cares about the exhaust valve
    I had to replace several wheels to bring the lugs back to acceptable
    Change to challenge engine mounts
    Your list of items reads like that of a typical 25 year old vehicle from ANY manufacture.
    If YOU want it perfect, it will come out of YOUR wallet.
  12. Uberpower
    Uberpower Formula 3
    1,116
    Oh really Mitch? Out of my wallet? Huh. I guess after owning four Ferraris and countless other exotics over 20 years I didn’t get that part. Thanks!
    And I’m not looking to make it “perfect” I’m looking to get a reasonable point-in-time snapshot of its condition so I can correct it. I was surprised at some of the findings.
    I’m glad you drive your 355. I intend to drive mine (has over 70k miles now) and I write partially to remind my future self of what I’ve done, my children for when I’m gone if they choose to keep the car and as a tertiary priority, to help the community in case they have a similar issue.
    I don’t appreciate the condescension. Take it somewhere else.
  13. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,930
    Richmond
    Pete
    I would replace those boots now (you don't want to have to replace the rack or axle), keep an eye on the valve covers once the lines are fixed and go from there. Also do the motor mounts, those are easy. The steering rack boot won't make the rack less precise, it'll potentially let dirt into the seals and ruin them creating a leak, meaning you are either rebuilding or replacing the rack, neither of which will be cheap or easy as that's apparently a pita job.
  14. Rifledriver
    37,299
    I understand not wanting to just throw a part at the car, you really want to prove its bad. In many cases it is just economically the sensible thing to do. Especially with an O2 sensor. I have personally seen them malfunction for a 5 or 10 second period and set a light. It was sheer luck I saw it. If you suspect it, or if there is an error for it, replace it. Its the only logical, cost effective way of dealing with it.
    bjwhite, muk_yan_jong and Uberpower like this.
  15. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #40 Ferrarium, Jun 24, 2024
    With many 30!year old parts installed beyond the service live, it may makes sense to replace many parts that are very cheap when suspected, crank sensors, cam sensor, O2 sensors, tps sensors, igniters, iac valves etc, sometimes the issues are intermittent due to age or fluid intrusion or wiring age etc. intermittent issues are the worst and paying a shop to not find it because of that is frustrating. Besides parts are consumable and we’re not designed to live forever. Likely 10 year high time on most replaceable components.
    For many taking it to a shop will cost more to diagnose issues than replacing all those.
    For any issue there is not normally that many things contributing to it.
    just a thought.​
