Rattling Belt? Something Worse? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Santos, Aug 20, 2013.
  1. Santos
    Santos Rookie
    Oct 27, 2012
    49
    New York, NY
    Gentlemen,
    I hope you could help by providing your insights as to what might be causing the infernal rattling coming from under the bonnet of this 412.
    IMG 0552 - YouTube
    Any ideas? Solutions?
    Thanks,
    Robert
  2. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,670
    Youtube diagnosis, always accurate :)
    Sounds mechanical, not a belt.
    I wouldnt be running that engine though - could be very loose cam chain, valve problem, broken drive key for the brake vacuum pump and many other things. With the bonnet open and a stethoscope you could narrow it down quite a bit.
    Looks like its in a dealership, what to they say ?
    M
  3. Santos
    Santos Rookie
    Oct 27, 2012
    49
    New York, NY
    Thanks for the reply. The dealership and associated local independent service station both agree that this is nothing more than a loose fan belt.
    Frankly this seems ridiculous at best.
    I've had the chance to test drive "Ashman"'s 400i and a local 400gt. Never heard a symphony like this.
    I'm going to give it a test whirl this weekend and hope nothing breaks while I'm driving it.
  4. Ak Jim
    Ak Jim F1 Veteran
    9,479
    North Pole AK
    Well, a loose fan belt would be easy to check. Just try pushing on them. It could be a loose cam chain.
  5. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,670
    I hope they don't think there are "fan" belts as such - the fans are electric fans.
    There are dual belts for the A/C compressor ( and the rattle could be coming from the compressor, didn't think of that ) dual belts for the power steering pump and a belt for each alternator (there are 2 alternators) . Adjusting or replacing the belts takes a bit of time, bit like a Rubiks cube, needs to be done in the right order :)
    M
  6. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    736
    Lake Stevens Washington
    Howard Musolf
    I had a very similar noise in my 1982 400. I thought chain, idler, or worse. I used an electronic stethascope and could not pinpoint the noise any closer than the lefthad front side of the motor around the timing chain case.
    On a whim I grabbed a can of belt dressing and sprayed the alternator belt and the noise dissapeared. I replaced both alternator belts with new cogged back belts and no more noise.
    just sayin'
    Howard Musolf
    1981 308gtsi
    1982 400i Cabriolet
    1994 348 spyder
  7. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,021
    MA
    #7 Ashman, Aug 20, 2013
    This is what it sounds like to me without actually being there. There are two thin belts driving the alternators (and for the PS as well as the AC but the alternator belts seem to be the culprits most of the time) and they can be noisy with a loud ticking or clacking sound, almost like electrical "snapping", if the car is not driven regularly, possibly because the rubber stiffens or hardens with age and takes a set in the position that it has been sitting in. This is the sound that the belts on my car made when I bought it and it had been driven only 4,000 miles in 10 years in southern California.
    Sometimes it goes away after a few minutes and the belts have warmed up but I suppose in cases where the rubber in the belt has hardened, it persists for a while. People have achieved a temporary fix by spraying with WD40 or even water but I think that the main problem is that they are due for replacement.
    All of the belts are inexpensive to buy, a bit of a pain to replace, particularly the lower alternator belt, but that should solve the problem. Just keep track of which belt is which because they have different sizes and part numbers but look very close in size. If you mix them up you will go crazy trying to get them sorted out.
  8. Santos
    Santos Rookie
    Oct 27, 2012
    49
    New York, NY
    Thanks all, I will follow up after I learn more.
  9. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    +1 on the Alt. belts, go there 1st :D
  10. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    A chattering V belt can make some ominous sounds, perhaps this it. If the dealer is convinced it is this simple he ought to be able to correct it in a flash. Telling of his used car prep beyond a wash.
    A bar of soap against the sides of the belt will provide enough lubrication to stop the chatter until a fresh belt can be installed. It's NOT a tension issue, the belt(if indeed the source)is either old and hard or glazed.
  11. aidanparte
    aidanparte Formula 3
    Jul 18, 2004
    1,231
    If you buy this car, or need a PPI, I would take it to Bill Pollard (Sport Auto) in Gaylordsville, Connecticut.
    Aidan
  12. rovexienus
    rovexienus Formula Junior
    587
    Sainte Colombe, France (near Lyon)
    Jean-Michel Savary
    Hi Robert,
    I have a 1988 412 with little mileage (less than 10.000 km) which makes a similar noise at start for about 5 minutes, then that noise goes away. Same for a 1983 400i (78.000 km). I was told that the noise comes from the belts. I will make a video for these cars at start and post the video.
    Regarding the wheels of that 412, they look very similar to the wheels on the car shown in the following post:
    https://www.ferrarichat.com/forum/365-gt4-2-2-400-412/419002-anyone-know-these-wheels-car.html
    Would you have information about brand/type/size of the wheels on the 412 in the video?
    Thanks in advance
  13. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    29,721
    North Qld
    simon klein
    #13 simon klein, Aug 21, 2013
    Riiight,having checked out all the replies to this thread(and wondering what actual noise you are all talking about),I am thinking it's the 'crackling 'type sound???
    My 365 makes it when cold as does a C4 owner's car,my mechanic says it's normal for them to make the noise.
    Unsure if the 400/412 does the same.
    Just got off the phone from Marc re this,if it's the crackling noise,it's the drive belts,early in the morning,if they have some 'sheen' on them it happens,it also happens on 308's,apparently.
    My car has always made this noise since purchase,it hasn't affected it's performance at all........................................it'll still drag the pants off any 400......................................
    ......running...:)
  14. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,602
    +365
    If its a ticking/cracking sound on start up that goes away once the engine is warmish, its the alternator belt. I have a brand new engine and it still does it occasionally
  15. peder412
    peder412 Rookie
    Dec 27, 2003
    14
    Sweden
    Peder Hansen
  16. Santos
    Santos Rookie
    Oct 27, 2012
    49
    New York, NY
    Well, I saw and test drove the car and as you wise men all said, the belts warmed up and stopped rattling/clicking/tapping.
    I'll post a few pictures and ask a few more questions later tonight when I get access to my home computer.
  17. Santos
    Santos Rookie
    Oct 27, 2012
    49
    New York, NY
    #17 Santos, Aug 26, 2013
    So, this car is currently available at Exotic Classics in Syosset, NY.
    They quoted me an aggressive ask of $46 or $48 - don't remember which - which may keep some buyers away as the car had some issues.
    First the good news was that the engine turned right over and showed fantastic power and acceleration up to +/- 90 mph with three full-sized adults on board. The suspension seemed to be almost all new, the ride was firm but comfortable with no jarring coming through to the cabin. Steering was true and aligned.
    Bad news that stuck out was a little more extensive.
    After that 90mph run the brakes almost completely gave out causing a cardiac condition on slowdown. At the end of the exit ramp the car was smoking heavily from the right front. Braking was very weak for the remainder of the trip back to the shop. Underside of the oil pan and crossmember was heavily coated in oil, seemed like there was a seeping gasket or two above.
    In the engine bay, two small fuel lines which seemed to be attached to what I would call the "frequency valve" on my old Bimmer were disconnected entirely, meaning that whatever rudimentary lambda control CIS has would not function on this car. These lines were tied up and exposed next to the right-bank WUR. Leads me to believe that the car was pre-warmed up and may have cold-starting issues.
    Inside multiple center stack dash controls did not work, and we could not examine the boot. Power seats only worked front to back.
    A/C worked but only out of the passenger side of the car. Maybe I didn't know how to turn on the other side?
    I think the search must continue.
  18. GT Jones
    GT Jones Formula Junior
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    What repair work can you do on your own? Chances are good that any car for sale will have immediate needs. I'd start with only looking at colors and models that appeal to you then work up a list of repairs.
  19. rovexienus
    587
    Jean-Michel Savary
    Hi Santos,
    Do you have the details for the wheels installed on this 412 (rim and tyre nature and size)?
    Thanks in advance
  20. Santos
    Santos Rookie
    Oct 27, 2012
    49
    New York, NY
    The seller claims they are custom rims. I didn't look at them closely enough to see manufacturer's marks.
