Re-shocks and spring seperation | FerrariChat
Discussion in '308/328' started by roalda, Jan 10, 2010.
  1. roalda
    roalda Formula Junior
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    #1 roalda, Jan 10, 2010
    Hi, Guys need some help.
    I have removed my shock/spring assembley but dont know how to seperate the spring from the shock, does this have to be done at a specialist or can i do it at home, if so do i need any specialist tools? 1989 328gts if this helps.
    Regards, Roy
  2. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    #2 st@ven, Jan 10, 2010
    you need special tools.
    These are what i've home-made ( 20+ years ago) and use for my cars but there are better (and saver!) tools available nowadays.
    For safety reasons only, considder a pro for this job.
  3. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    #3 roalda, Jan 10, 2010
  4. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Take them to a shop that does this type of work, e.g. any shop that does macpherson struts. Since you are likely to do this work only once it is not worth getting an arbor press, making attachments, etc.
    The energy stored in those springs once compressed is lethal.
  5. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    not sure. The space at the spring at the absorber side is pretty narrow. I think this tools hook might be too big
  6. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    Steven have you any pics of your shock re-build i can look at?
    Regards Roy.
  7. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    what exactly are you looking for?
  8. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    How you take them apart and reasemble.
    Regards Roy.
  9. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
  10. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    #10 CliffBeer, Jan 10, 2010
    Roy, yes, those spring compressors will work just fine.
    There's another DIY version which is very similar, but a bit safer, as it has pins that positively located the spring within the hook - I use this version and it works great and is pretty close to 100% safe.
    But yours should be fine, no need to waste the time and money on a specialty shop for such a simple job. For a little extra safety you might want to use two pieces of rope on each spring - one each running parallel to the compressor - which you can progressively tighten as the spring compresses (and then slowly release as the spring is being released).
    Good luck!
  11. dwhite
    dwhite F1 Rookie
    I have used spring compressors for years. I do like the little extra safety Cliff shows - never saw one like that. It is a simple procedure to change the springs. The key is take your time and make sure the spring compressor is on the spring securly then just slowly toggle back and forth between the 2 sides to compress evenly.
  12. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    +1 please be very careful I've been taking struts apart for for about 20+ years.
    Has not happen to me (thank God) but I've heard people died from mishandling the strut assembly when the spring came loose and someone got hit on the chest and severely got injured to near death. Not trying to scare you but please treat it like a bomb with lots of respect.
  13. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    There are many slightly different spring compressors out there.
    A few cautions, keep the two bolt type compressors directly opposite each other, if they are not directly opposite, they can slide on the spring with potentially bad results.
    Second, make sure that the hooks do not press on the shock body, it may dent the tube and if you are going to try to rebuild the shock, this could screw up a shock body.
    While it is true that the original Konis are adjustable, they are not easily adjustable. Having to use a spring compressor to get the spring off to fully compress the shaft to make the adjustment is a lot of work. Just turning an exterior knob is the way to go :)
    chris
  14. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    One other thing about using a spring compressor. Mine have a safety clamp to keep the compressor connected to the spring. If the compressor slips off the spring, the clamp (theoretically) keeps whole thing from flying apart.
  15. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    #15 roalda, Jan 11, 2010
    Thanks guys for your advice, i have managed to get them apart useing the spring compressor i did strugle trying to remove the base plate for the spring (rust) it gave in after lots of wd40 and several taps with a rubber mallet.
    A point of interest the shocks are made in Germany by Bilstein and are not Koni,s i think this was part of the revised suspention for late 1988-1989 models (i think)???
    Regards Roy
