360 - Reading and understanding F1 clutch wear | FerrariChat
360 Reading and understanding F1 clutch wear
Discussion in '360/430' started by tomw, Mar 27, 2023.
  1. tomw
    tomw Formula 3
    2,413
    London
    Tom
    I'll start by saying I fully understand the wear readings are of questionable accuracy and usefulness, but anyway...
    My car (CS) was serviced in October and I was told it had 27% wear on the clutch. Since it was serviced the car has sat in my garage apart from about 2miles up and down the road here in January. I then drove it about 15 miles to a different shop to have some other bits done last week. Today this shop has told me the clutch is approx 70% worn.
    Both these are highly respected Ferrari specialists, so they can't both be wrong... But I doubt I've done almost 50% of a clutch in less than 20 miles of gentle driving, so one of them must be wrong.
    Logic tells me one of the shops has mis-read the wear reading and, instead of it being 27% worn it's actually got 27% left. Or the other shop's done the same thing and it's really got 70% left...
    So two questions:
    1. Is the figure the computer gives you a 'worn' or a 'remaining' value?
    2. What's the easiest (cheapest) way I can read it myself and check the values with my own eyes? I already have OBD2 stuff for the car but nothing Ferrari specific and don't really fancy buying an X431 just yet. Although maybe I'll have to when I end up working on the car myself(!)
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,694
    Central NJ
    Dominick
    The computer shows "worn" ..
    It is only as good as the number that is stored in the TCU ( inputted at clutch change) - Clutch position from new - if this was entered wrong you will not have any good data
    An old AP200 ( white) by autel or the thinkdiag 1 or 2 are good choices for you
    Have someone look at the clutch thru bottom panel .. if grooves are gone you are at 70 + percent worn
  3. tomw
    tomw Formula 3
    2,413
    London
    Tom
    That was fast, thank you! Yeah, I understand the limitation on the reading only being as good as the data put in when it was replaced and calibrated but I just wanted to see the actual value for myself. I'll ask if they can take some photos through the bottom while they've got the car in the air - good idea.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,694
    Central NJ
    Dominick
    How many miles in the clutch .. ..you can use as a sanity check
  5. tomw
    tomw Formula 3
    2,413
    London
    Tom
    I don’t actually have an invoice for one. The car’s only done about 17,000 miles so it could be original… But I doubt it.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,694
    Central NJ
    Dominick
    at 17,000 miles you should have at least 65% left
    tomw and RobinMasters like this.
  7. Mario Andretti
    Mario Andretti Formula 3
    1,760
    Boston
    Get this tool. It's great. For me, it does whatever the X431 launch does, including bleeding the clutch, setting the PIS, check and delete all error codes, read live data (including clutch wear) , etc.
    I would say the AP200 is also good, but seeing the price has gone up to almost 70 bucks, and this is 119, it's a no brainer. The AP200 can only read stuff and erase codes, no clutch bleeding or writing values into the TCU (setting PIS for example).
    https://www.amazon.com/Thinkdiag-Bluetooth-Bidirectional-Diagnostic-Functions/dp/B08YWTJY4F/ref=sxts_rp_s_a_1_0?content-id=amzn1.sym.eff26b9b-e255-411b-a40d-eccb21f93fe4%3Aamzn1.sym.eff26b9b-e255-411b-a40d-eccb21f93fe4&crid=2HWSOTHEC5ZY5&cv_ct_cx=thinkdiag&keywords=thinkdiag&pd_rd_i=B08YWTJY4F&pd_rd_r=5dd085b3-688e-49fb-8524-b71ab0a196ab&pd_rd_w=53Mh1&pd_rd_wg=wABiA&pf_rd_p=eff26b9b-e255-411b-a40d-eccb21f93fe4&pf_rd_r=8E5ZS68KK3JT6EJ6VC7S&qid=1680183580&sbo=RZvfv%2F%2FHxDF%2BO5021pAnSA%3D%3D&sprefix=thinkdiag%2Caps%2C79&sr=1-1-5985efba-8948-4f09-9122-d605505c9d1e&ufe=app_do%3Aamzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
    CoreyNJ likes this.
  8. tomw
    tomw Formula 3
    2,413
    London
    Tom
    Nice, thanks.
    I have read that these thinkdiag things don't work so well with iPhones and Android is a better choice. Is this true? Does anyone use one with an iPhone and a 360, CS or 430?
  9. tomw
    tomw Formula 3
    2,413
    London
    Tom
    My car has lived in Milan and London during its life so it's probably had a lot of first-gear takeoffs in those 17,000 miles!
    Anyway I picked it up from the shop earlier and the car feels superb, so no plans to replace the clutch any time soon. I'd still like to be able to read these values myself though, so thanks again for the advice.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,694
    Central NJ
    Dominick
    Although I mentioned the old ap200 , the thinkdiag 1 or 2 in post #2 ..after seeing what you need and how you were going to use it ..the AP200 for 58 dollars on amazon right now is a good choice. No expiration of the brand vs subscription on Thinkdiag
    Looks like you just want to poke around and see data - the AP200 will suit you well .. it works on iphone as many on here have use it ..
    https://www.amazon.com/Autel-Scanner-Bluetooth-Diagnostic-Functions/dp/B07Y8HLS33/ref=asc_df_B07Y8HLS33/?tag=hyprod-20&linkCode=df0&hvadid=385178051407&hvpos=&hvnetw=g&hvrand=12253805449768266520&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9003674&hvtargid=pla-838366165169&psc=1&tag=&ref=&adgrpid=78533818717&hvpone=&hvptwo=&hvadid=385178051407&hvpos=&hvnetw=g&hvrand=12253805449768266520&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9003674&hvtargid=pla-838366165169
    Also you can return if you want
  11. Mario Andretti
    1,760
    Boston
    I have not used the Thinkdiag on iphone (but I can test) , only on my Android phone. I did use the Ap200 on my ipad though, so it works on iphones too I guess.
  12. CoreyNJ
    CoreyNJ Formula 3
    2,379
    New Jersey Shore
    I have both an AP200 and the ThinkDiag with my iPhone. Since getting the ThinkDiag I don’t use the AP200. The ThinkDiag is bidirectional but the AP200 isn’t. Big difference when you need to do more than just read the clutch data or reset a CEL.
    tomw likes this.
  13. Mario Andretti
    1,760
    Boston
    I had to pay to get mine working again last year, it does expire (or mine did) :
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,694
    Central NJ
    Dominick
    The AP200 doesn't have to be renewed .. I have one .. not sure what happened there
    One brand lasts for ever .. unless you bought other brands ??
    Compatible with iOS and Android devices (even for the latest version of iOS 13 and Android 10), not available for tablets
    ➤➤ Support all OBDII functions as well as 19 enhanced service functions
    ➤➤ First vehicle software is free with all systems diagnosis and service functions, which is the perfect gadget for car owners
    ➤➤Designed with a free APP, easy-to-use and multifunctional, supporting free update for lifetime
    ➤➤Wider vehicle coverage
    ➤➤Record history diagnostic data
    ➤➤A detailed manual to help use This creative car code scanner is primarily designed for home DIYers.
    Featuring one free vehicle-specific software, it allows you to test the specific vehicle for a lifetime without extra money.
    Free lifetime update service is also allowed to get the latest version of the AP200, from which you can get the bugs fixed timely.
    If you want to diagnose any other car models, you just need to cost $21.99 to buy 12-month use permission of each car software, and then related car systems diagnoses and reset services will be supported.
  15. Mario Andretti
    1,760
    Boston
    I read that, and you are right, it supposed not to expire. I just found mine last year asking for renewal all of a sudden, just sayin... I complained to them and never got a reply back :(
    But if I was to pay for it again, I won't, I'd rather pay for the Thinkdiag, much more useful.
    flash32 likes this.
  16. CoreyNJ
    CoreyNJ Formula 3
    2,379
    New Jersey Shore
    I think the 1st brand you register with Autel doesn't expire, but any others do. My Ferrari one works, but my Porsche one I added later on expired.
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,694
    Central NJ
    Dominick
    That would be correct
  18. Mario Andretti
    1,760
    Boston
    Ok, mystery resolved, customer service got back to my email (so email them if you want contact, don't try the phone). My mistake, I bought the wrong device, which has one year free for one car, not lifetime free:
    Make sure you buy the AP200, not the AP200M if you want lifetime update for one car.
