Reading Bosch/Stribel relays | FerrariChat
Discussion in 'Technical Q&A' started by REM9, Dec 29, 2003.
  1. REM9
    REM9 Karting
    Jun 17, 2001
    175
    Finger Lakes NY, USA
    Russ Moore
    After a recent bout with a tempermental relay failure in a TR, I happened across the below information and thought it might be helpful to someone in the future.
    Russ
    Terminal Definition
    IGNITION
    1 Ignition coil, ignition distributor, low voltage
    (Ignition distributor with two separate electrical circuits)
    1a to ignition contact breaker I
    1b to ignition contact breaker II
    2 short-circuit terminal (magneto ignition)
    4 Ignition coil, ignition distributor, high voltage
    (ignition distributor with two separate electrical circuits)
    4a from ignition coil I, terminal 4
    4b from ignition coil II, terminal 4
    15 Switched + downstream of battery
    (output of ignition/driving switch)
    15a Output at dropping resistor to ignition coil and starter
    GLOW PLUG AND STARTER SWITCH
    17 Start
    19 Preheat
    BATTERY
    30 input from + battery terminal, direct
    30a input from + terminal of battery II
    (12/24 V series-parallel battery switch)
    31 Return line to battery
    - battery terminal or ground, direct
    31b Return ine to negative battery terminal or ground, via switch
    or relay (switched negative)
    (12/24 V series-parallel battery)
    31a Return line to - terminal of battery II
    31c Return line to - terminal of battery I
    ELECTRIC MOTORS
    32 Return line
    (Polarity reversal possible at terminals 32-33)
    33 Main terminal connection
    33a Self-parking switch-off
    33b Shunt field
    33f For second lower-speed range
    33g For third lower-speed range
    33h For fourth lower-speed range
    33L Counterclockwise rotation
    33R Clockwise rotation
    STARTER
    45 Separate starter relay, output; starter input (main current)
    45a Output, starter I
    Input, starters I and II (Two-starter parallel operation)
    45b Output, starter II (Two-starter parallel operation)
    48 Terminal on starter and on start-repeating relay for
    monitoring starting procedure
    TURN SIGNAL FLASHER
    49 Input
    49a Output
    49b Output, second turn-signal circuit
    49c Output, third turn-signal circuit
    STARTER
    50 Starter control (direct)
    50a Output for starter control
    (Series-parallel battery switch)
    50b Starter control with parallel operation of two starters with
    sequential control
    50c Input at starting relay for starter I
    (Starting relay for sequential control of the engagement
    current during parallel operation of two starters)
    50d Input at starting relay for starter I
    50e Input, Start-locking relay
    50f Output, Start-locking relay
    50g Input, Start-repeating relay
    50h Output, Start-repeating relay
    ALTERNATOR
    51 DC voltage at rectifier
    51e DC voltage at rectifier with choke coil for daytime driving
    TRAILER SIGNALS
    52 Signals from trailer to towing vehicle, general
    WIPER MOTOR
    53 Wiper motor, input (+)
    53a Wiper (+), self-parking switch-off
    53b Wiper (shunt winding)
    53c Electric windshield-washer pump
    53e Wiper (brake winding)
    53i Wiper motor with permanent magnet and third brush (for higher
    speed)
    TRAILER SIGNAL
    54 For lamp combinations and trailer plug connections
    TRAILER STOP LAMP
    54g Pneumatic valve for additional retarding brake,
    electromagnetically actuated
    LIGHTING
    55 Fog lamps
    56 Headlamp
    56a High beam, high-beam indicator lamp
    56b Low beam
    56d Headlamp-flasher contact
    57 Side-marker lamp: motorcycles, mopeds.
    Abroad also cars, trucks, etc.
    57a Parking lamp
    57L Parking lamp, left
    57R Parking lamp, right
    58 Side-marker lamps, tail lamps, license-plate lamps and
    instrument-panel lamps
    58b Tail-lamp changeover for single-axle tractors
    58c Trailer plug-and-receptacle assembly for single-conductor
    tail-lamp cable with fuse in trailer
    58d Variable-intensity instrument-panel lamp, tail-lamp and
    side-marker lamp
    58L Side-marker lamp, left
    58R Side-marker lamp, right; license-plate lamp
    ALTERNATOR (magneto, generator)
    59 AC voltage, output
    Rectifier, input
    59a Charging armature, output
    59b Tail-lamp armature, output
    59c Stop-lamp armature, output
    61 Alternator charge-indicator lamp
    TONE-SEQUENCE CONTROL DEVICE
    71 Input
    71a Output to horns 1 & 2, low
    71b Output to horns 1 & 2, high
    72 Alarm switch (rotating beacon)
    INTERIOR
    75 Radio, cigarette lighter
    76 Speaker
    77 Door-valve control
    SWITCHES
    ----------(Break-contact and changeover switches)----------------------
    81 Input
    81a 1st output, break side
    81b 2nd output, break side
    ----------(Make-contact switches)--------------------------------------
    82 Input
    82a 1st output
    82b 2nd output
    82z 1st input
    82y 2nd input
    ----------(Multiple-position switches)---------------------------------
    83 Input
    83a Output, position 1
    83b Output, position 2
    83L Output, left-hand position
    83R Output, right-hand position
    CURRENT RELAY
    84 Input, actuator and relay contact
    84a Output, actuator
    84b Output, relay contact
    SWITCHING RELAY
    85 Output, actuator (end of winding to ground or negative)
    86 Start of winding
    86a Start of winding or 1st winding
    86b Winding tap or 2nd winding
    ----------(relay contact for break and changeover contacts)------------
    87 Input
    87a 1st output (break side)
    87b 2nd output
    87c 3rd output
    87z 1st input
    87y 2nd input
    87x 3rd input
    ----------(Relay contact for make contact)-----------------------------
    88 Input
    ----------(Relay contact for make and changeover contacts (make side))-
    88a 1st output
    88b 2nd output
    88c 3rd output
    88z 1st input
    88y 2nd input
    88x 3rd input
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,858
    The Cold North
    Tom
    cool! thanks!!
