really, REALLY hard brake pedal on MndialT | FerrariChat
Discussion in 'Mondial' started by russlv, Jun 9, 2012.
  1. russlv
    russlv Karting
    Feb 29, 2012
    63
    las vegas, nv,
    Russ Lorenzen
    #1 russlv, Jun 9, 2012
    I just brought my '91 MondialT out of storage, and now feel like I have to be
    an olympic body builder to push the brake pedal down. The car stops ok, but
    the presure required is A LOT! I checked all four corners and everythink looked ok.
    The fluid level in the master is good with no leaks. I'm thinking taht maybe the
    booster has gone south. Any idea on how to test it would be helpful.
    Thanks,
    Russlasvegas
  2. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I know on the 3.2 there is a vaccum check valve right by the engine that comes off the intake manifold. The line then runs all the way to the front to the booster. If that valve is stuck we get a similar issue. If your car has the same bit that might be a first place to check. I took mine off the car cleaned it and it works much better. Initially mine still mostly worked but did the hard brakes sometimes when I first fired it up after sitting. After cleaning it, no problems.
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    your accumulator pressure ball is shot...
  4. russlv
    russlv Karting
    Feb 29, 2012
    63
    las vegas, nv,
    Russ Lorenzen
    Hi,
    I looked at the parts list and I'm quessing that I need accumulator kit part # 700000504.
    Is that the part that you feel might need replacement? Any thoughts on where to get it,
    or is not a diy type project?
    Thanks,
    Russlasvegas
  5. tonymondial
    tonymondial Rookie
    Sep 25, 2024
    10
    antonio dizazzo
    hi, did you fix your problem? If so, where did you find the parts? I'm having the same problem.
  6. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
  7. Alden
    Alden F1 Rookie
    3,601
    Central Florida
    12-Year-Old post, he's come and gone for sure!
    Alden in
