348 - Rear Axle temp vs Front | FerrariChat
348 Rear Axle temp vs Front
Discussion in '348/355' started by MaseratiSD, Sep 16, 2023.
  1. MaseratiSD
    MaseratiSD Rookie
    23
    Los Angeles
    Philip
    I know there have been issues with the rear brake delay valve on 348s, but I don't think that's my issue. The rear wheels get about 20 degrees hotter than the front. The rear wheels are 100 Degrees F when the front's are 80 F or less.
    -- I did check and the parking brake is not stuck on. The cables are loose.
    The odd thing is the rear axles are hot, like 120 degrees F, which I presume is why the actual wheels are 100 degrees F.
    Is this normal?
    Was hoping someone else has seen this and can tell me it happens all the time!
    Best Regards, MaseratiSD
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    Terminology and pointing fingers::
    Wheels are hotter implies heat is being added from somewhere {bearing going out, heat transfer from sticking caliper through rotor, outer CV joint is going out, ...} If both wheels are doing this it is probably normal.
    Tires are hotter overall implies too much toe-in,
    Tires are hotter inner edge implies too much camber,
    Tires are hotter outer edge implies too little camber.
    Rear axles are close to exhaust and get radiative heat transfer when you run the car hard (like you are supposed to).
    But before you read too much into the above--you need to remember:: tires are supposed to run close to 200ºF when you are thrashing the car within an inch of its life. 100º is (as they say) nothing.
    In all my years of running the snot out of my F355, I never bothered at all with wheel temperatures--tire temperatures are critical--wheels are just along for the ride.
    Qavion likes this.
  3. fdekeu
    fdekeu Formula Junior
    631
    Belzium
    Frank
    Rear axles get heat from the transmission and the heat generated in the CV
    Also radiation from the exhaust
    Wheels get heat from brakes and tires
    Tires warm up from rolling resistance and during braking
    The rear ones also from the engine power
    Rear tires and wheels are normally a bit warmer in my experience
    20F is normal in my opinion
  4. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    The rear axles are inches from the catalytic converters that are well over three hundred degrees Just for them to start working that is, they get double that.
    The front wheels are inches from well.... nothing but cool air.
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,217
    Serbia - Niš
    Miroljub Stojanovic
    The rear tyres also get some heat from the radiator fans. It all adds-up.
