News
Rear Brake Line Source
Discussion in '308/328' started by TURBOQV, Oct 24, 2009.
  1. TURBOQV
    TURBOQV Formula Junior
    Mar 6, 2003
    838
    NV and Socal
    #1 TURBOQV, Oct 24, 2009
  3. ALUMINUMYELLOW328
    ALUMINUMYELLOW328 Formula Junior
    May 30, 2004
    381
    Bergen County, NJ
    Rhett R Arcilla
    Try Martin from ********, he might be able to help you.
  4. TURBOQV
    Mar 6, 2003
    838
    NV and Socal
    I bought rear rotors from him but he did not have stainless steel brake lines. I doubt he will have these, but i will give it a try.
    Thanks again
    Paul
  5. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    3,868
    San Jose area
    Brian Harper
    I bought the straight piece of line from my local auto parts store - it was special order because of the unusual metric double flare - and bent it up to fit by my self. Not a big deal. It seems like any competent brake mechanic should be able to replicate it if I could do it myself on my first try.
  6. Dr_ferrari
    Dr_ferrari Formula 3
    Professional Ferrari Technician Consultant
    Nov 2, 2003
    1,065
    Pocono Sportscar
    Jim McGee
    If you are in need of the line, I can duplicate if you wish. I have a hose and fitting/line repair shop in house here and we have all the line and fittings you need.
    Regards, Jim
  8. TURBOQV
    Mar 6, 2003
    838
    NV and Socal
    That would be awesome!
    Thank you!
    Paul
  9. Nurburgringer
    Nurburgringer F1 World Champ
    Jan 3, 2009
    10,615
    Texass
    just sent a PM to the good Dr. about this, but if anyone has input I'd sure appreciate it.
    I'm replacing the rear brake lines on my 1985 308 QV while the motor is out - they're pretty dinged up and removed them anyway to clean/paint the frame.
    Is this 'special' tubing, or will the straight pieces I just picked up from NAPA work after they've been trimmed to length and bent? Rather than spend ~$100 on a cutting/bubble end kit I'll find a brake shop to do it for hopefully $10.
    Napa only had US fractional sizes brake lines (said there was no such thing as 'metric' brake lines?). The 3/16" tube looks to be the same diameter as OEM, has the 'bubble' ends, and the ferrules seem to be the same thread size.
    Instead of replacing the long line going from the front of the car back to the 3-way I'd like to splice in a piece about 3' long, joined with the existing tube with a female-female coupler right behind the firewall. I bought a coupler at NAPA and it threads nicely with the exiting ferryule and the new one.
    I got the ~7" long line going from the rear 3-way to drivers side wheel from Rutlands for $5, but they didn't have the other two (3-way to passenger wheel and master cylinder to 3-way) in stock so trying to do this with locally available tubing if possible.
    Appreciate any input!
    thanks
    Kurt
  10. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    I ruined one of my lines and made one from the 'universal' premade lines at PepBoys. As I recall, I think the lines marked "European" had the correct ends. Just walk back there to the display on the wall and pick the one with ends that match yours. Mine had standard US pipe threads and was easy to match.
    I think they were $3 each so I bought a few and then kept trying til I got one bent just right.
  11. Nurburgringer
    Jan 3, 2009
    10,615
    Texass
    thanks - I'll stop by Autozone tomorrow to check their supply, but it sounds like the ones I bought are good to go. Just was strange to me to buy a brake line at Napa, a '3/16"' one at that, but I see that accd to http://www.fedhillusa.com/ the US ferrule is 24 pitch so I'll call that close enough to 1mm for the relatively short amount that'll be threaded.
    Now I just need to find is someone with one of these:
    http://www.youtube.com/watch?v=J5p7BKc7bok
    cheers
  13. Peter
    Peter F1 Veteran
    Rossa Subscribed Owner
    Dec 21, 2000
    6,406
    B.C., Canada
    #10 Peter, May 3, 2010
    I used 3/16" tubing (with metric nuts that properly fit the 3/16" tubing) on my car and popped out the flares using the Fedhill tool.
  14. TURBOQV
    Mar 6, 2003
    838
    NV and Socal
    #11 TURBOQV, May 3, 2010
    Jim did me a huge favor and fabricated these for my car. The price was very reasonable and the turnaround time was less than a week. I highly recommend him to you for your brake lines. I didn't have the time nor the talent to make them myself and a very special Thank You to Jim McGee of Pocono Motorsports for doing it for me and responding to my post.
    Cheers!
    Paul
