Rear brake pad replacement - $1800 | FerrariChat
Discussion in '458 Italia/488/F8' started by number_six, Oct 15, 2015.
  1. number_six
    number_six Rookie
    Apr 24, 2013
    30
    To replace both rear brake pads, my dealer is quoting me $1800. Has anyone else had to do this and can confirm this is reasonable? Sounds way too high to me. All they have to do is remove the wheels, unpin the calipers and replace the pads. I used to do this on my BMW. Is this kind of work worth outsourcing or are the parts really that expensive?
    Thanks!
  2. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,196
    Orange, Calif
    I am surprised that rear ones are needed replacement before the front.
  3. Caeruleus11
    Caeruleus11 F1 World Champ
    11,612
    On these newer cars like the 458 the rears get involved with cornering sometimes.
    I think the cars computer needs reprogramming or resetting a parameter or some such thing so its likely you will need the dealer. And the pads are not cheap. I wouldn't be surprised if they wanted that for the pads alone.
    If you have relatively low miles on your car I'd want them to show me the pads themselves as well as the computer read out that states the pads need replacing.
  4. Jasone
    Jasone Formula 3
    Nov 15, 2011
    1,203
    Tampa Florida
    Jasone
    #4 Jasone, Oct 15, 2015
    That's the price for driving these cars in Sport or even Race. I always drive my car in CT-Off primarily to gain control of the rear wheels but as a side benefit to save my rear brake pads. If you've been driving the car hard in Sport or Race.. your rear brakes have been gripping your rotors..
    To answer your question.. yes, the rear pads need to be replaced before the fronts (if you've been driving in sport) and they are expensive.
  5. colonels
    colonels Formula Junior
    Aug 5, 2011
    877
    how many miles?
  6. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Your BMW likely had steele brakes while your 458 has CCM brakes... big difference in cost of pads... Rear pad set for 458 is listed for $2260 at Ricambi America: ferrari 458 Italia Parts : Table 29 - REAR BRAKE CALLIPERS
  7. jazztrip
    jazztrip Karting
    Oct 1, 2011
    173
    Austin, TX
    Joe
    @number_six, yes the parts are that expensive; at least for the OEM parts. I replaced the fronts and rears on mine earlier this year and the pads alone were ~$4000. My car had about 30,000 miles at the time including several track days at COTA (pretty hard on brakes and tires). You can switch to Pagid pads for much less although my dealer was reluctant to install them (he had less familiarity with the Pagid pads for ceramic brakes on the 458)
  8. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,196
    Orange, Calif
    [QUOTE You can switch to Pagid pads for much less although my dealer was reluctant to install them (he had less familiarity with the Pagid pads for ceramic brakes on the 458)[/QUOTE]
    I had Pagid pads installed on my Scud front brakes is much cheaper and stopping power is much better as well.
  9. tm22brz
    tm22brz Rookie
    Oct 28, 2014
    45
    how many miles does it take to replace the pads?im at 11k now..
  10. Gated
    Gated Formula 3
    Dec 21, 2009
    1,117
    Read pads likely need replacing first because of traction control engagement ;-)
    $1800 seems like a deal. Was $1900 to do the rear brakes on our Range Rover. $2500 to do the fronts! (they are larger Brembos than even the 458 though ;-)
  11. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    My 458 is a 2010 and with just 6800 miles I have not needed any brake pads.
    Not sure but I think Ferrari can be ordered with special brakes. They are expensive but are supposed to last the life of car.
    I bought one of my cars with these ceramic brakes. My 458 has standard brakes
    If you live near central Florida or can have your car sent here you may be in luck.
    The mechanic that does all of my cars was lead mechanic at a big local Ferrari dealer.
    I will put you two in contact if it helps. And yes that price sounds very expensive to me.
    Good luck what ever you do.
    Lee
  12. ferrariblue
    ferrariblue Formula Junior
    Jun 12, 2007
    548
    Houston, Texas
    Cody
    Let's put it this way, My Lexus ISF front Brembo pads alone were $600.00 at my dealer, and for steel brakes.
    I would expect to see your number, and not surprised.
  13. Gated
    Gated Formula 3
    Dec 21, 2009
    1,117
    Aren't all 458s on ceramic brakes?
  14. bigblock737
    bigblock737 Formula Junior
    Dec 19, 2013
    711
    Germany
    Andy B.
    Yes.
  15. number_six
    number_six Rookie
    Apr 24, 2013
    30
    Thanks for the responses. I have tracked my car 9 times (4 in race, 5 in CT off).
    Ferrame - Did the dealer install the Pagids on your scud? I have had good results with Pagid pads in the past (on my track BMW), never had any problems with them. Which pads did you use, and does your scud have carbon ceramic discs?
  16. jazztrip
    jazztrip Karting
    Oct 1, 2011
    173
    Austin, TX
    Joe
    Six, if you search the forums for pagid pads on a 458 you'll get a few responses. IIRC, folks have had good experience with them but make sure you look into the pads for ceramic rotors (I don't recall the part # but you'll find it in the search)
  17. maxvonauto
    maxvonauto Karting
    May 23, 2015
    159
    Corona
    Mark
    Use corvette ZR1 with ceramic rotor option pads. Cost about $450.
  18. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,196
    Orange, Calif
    I installed those pads myself on my Scud and they are "Pagid RSC1 U8091". All Ferraris built from 2008 have ceramic brakes as standard.
  19. racingbrake
    racingbrake Karting
    155
    Fullerton, CA
    Warren
