Rear Brake Part- 85 308 | FerrariChat
Discussion in '308/328' started by ferrariowner, Feb 27, 2016.
  1. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Does anyone have a source on the metal "freeze' plug on the bottom of the rear caliper. Mine started leaking and I hate to buy a whole kit just for one part.
  2. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    If the plug is leaking then you need to rebuild the hand brake system. If you need to do that then you should rebuild the caliper. If you rebuild 1 caliper you should rebuild the other.
  3. scudF1
    scudF1 F1 Rookie
    2,919
    Long Island, NY
    Billy
    In other words... Good luck. Lol
  4. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I rebuilt this caliper and parking brake about 6-7 months ago and it wasn't leaking then. It just started leaking today. Hard to believe it went bad so fast. It looks to me like I really didn't set the plug well the first time.
    SO why did I rebuild the caliper 6-7 months ago, it was a case of while your in there. :)
  5. ClydeM
    ClydeM F1 World Champ
    12,123
    Wayne, NJ
    Clyde E. McMurdy
    Search this forum or Tech. I do recall somebody found a source for the blank plugs. It was a few years ago.
  6. Steve King
    Feb 15, 2001
    4,367
    NY
    The plug is not the seal all it is there for is to keep dirt out of the adjustment screw. If brake fluid is leaking out of the plug then the seal is bad and needs to be replaced. You can get the caliper replacement seal kit from most of the suppliers on this form.
  7. Steve Magnusson
    26,944
    +1
    They're called "Welch Plugs" (or sometimes wrongly "Welsh Plugs"), but this is one of the reasons why I'd just send them to PMB for a good result at good value price - JMO (which is getting jaded...:()
  8. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Thanks for the responses guys. It looks like it time to rebuild.
  9. SteveG75
    SteveG75 Formula Junior
    Nov 23, 2010
    380
    FL
    Stephen
    For a rebuild, go to PMB. They just did mine and they look great. Car still on jackstands since I may need to do master cylinder and about to do timing belts.
