Rear diffuser mounting correctness | FerrariChat
Discussion in '348/355' started by 8500rpm, Nov 19, 2016.
  1. 8500rpm
    8500rpm Formula Junior
    May 20, 2014
    546
    San Francisco Bay
    Chan
    #1 8500rpm, Nov 19, 2016
    Hi guys, one of my diffuser exit panels is mounted wrong.
    The L-brackets attaching to the bumper can be mounted upside down, affecting the height of the diffuser exit. I thought the higher height (the one on the left below) was correct, but somehow the right side wouldn't match the bracket if mounted that way.
    Which one is correct? Pictures on the internet seem to be inconclusive. Thanks in advance!
    Ugly find: one of the brackets was glued onto the bumper. Someone didn't even bother to replace the missing screws.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #2 Dave rocks, Nov 19, 2016
    It's midnight and I'm laying on the floor taking pictures for you..........you owe me a beer :D
    And, dam - now I need to address the minor surface rust....
    Carry on :)
  3. Qavion
    Qavion F1 World Champ
    14,301
    Ian Riddell
    Ditto on my car, although I don't know if the bolts are standard. I have a larger black body washer and a dome headed hex keyed bolt holding the bracket to the diffuser. I don't have the rusty bracket, either (Don't know why, but I don't have that bracket at all).
  4. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Thanks! Sure thing, if you're ever in the Silicon Valley area.
    I've been laying on the floor every night trying to figure this out!
    Still not sure why just one bracket won't line up with the diffuser...will try switching the brackets around tonight. :D
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    95's (at least early ones) had the brackets molded within the bumper. The diffusers mount to the brackets (all years) with hex head fasteners.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    What, you aren't bringing the beer to me? :) :) J/K
    Losten the other fasteners holding the diffuser, align and tighten ;)
    Should line up just fine :cool:
  7. 308 GTB
    308 GTB F1 World Champ
    11,722
    New Jersey
    Barry Wolinsky
    #7 308 GTB, Nov 19, 2016
  8. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Exactly, I was able to get everything in after loosening an upstream bolt. Thanks for confirming the correct setup!
    Small job, but I feel better about having fixed yet another small issue. And to whoever glued on one of the brackets because the screws got lost......seriously?! :)
  9. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
    #9 phrogs, Nov 20, 2016
    Ive seen worse on a ferrari
    Like epoxying a cracked cam cover, I saw a oil leak turned out to be cracked.
    Nothing in my records about it no idea how it got cracked but its a crack, im a guess someone cracked it and decided this was best.
    Lazy work Whoever did it.
