Rear Diffuser question. | FerrariChat
Discussion in '308/328' started by scudF1, Sep 12, 2015.
  1. scudF1
    scudF1 F1 Rookie
    2,918
    Long Island, NY
    Billy
    The rear diffuser (diaper) on my 85' 308 is painted glossy black matching the two grills left and right under the fenders. Is this the right finish? My friend's 83' QV is painted in matte black finish. Any thoughts?
  2. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,329
    Montana
    Kim
    IIRC, My old 84 GTB had a matte finish. My Euro has no such piece.. Sorry.
  3. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    I've painted my 85 a satin finish
  4. scudF1
    scudF1 F1 Rookie
    2,918
    Long Island, NY
    Billy
    Are there any other 85' owners with a glossy finish diaper?
  5. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    Should be satin/semigloss. Definitely not gloss or matte. I have a new and never repainted one sitting in my garage.
  6. Dr Tommy Cosgrove
    36,474
    Birmingham, AL
    Tommy
    This
  7. tatcat
    Sep 3, 2001
    11,013
    rick c
    actually I used a wrinkle finish bed liner paint first then the satin
  8. MREUS
    MREUS Formula Junior
    Jul 24, 2006
    832
    Huntington Beach, CA
    #8 MREUS, Sep 13, 2015
    This was recently rebuilt and matches the previous diaper.
    Should be an original match since FCA judges didn't see anything wrong with it either.
  9. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    Same exact finish as mine.
  10. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    I had mine Powder Coated, Black, Semi-Gloss. Very reasonably priced, all 3 pieces and the Powder Coating is really tough. No Stone chips coming off the rear wheels. The original finish was powder coating as we had to media blast it before re-coating. My car had only done 28K at the time. It has just over 30K now... guess I should stop driving it anymore! Isnt it the "magical" 30K miles point?
  11. Rifledriver
    37,141
    Yea
    New off the shelf they were kind of shiny powder coat. I'd say satin or semi-gloss is a good description.
  12. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    I had mine powdered coated in satin black.
  13. Gordo308
    Gordo308 Karting
    Sep 2, 2013
    98
    Essex, CT
    Gordon Laing
    This a timely post. I'm about to refinish all three pieces.
    Should I rivet the side pieces back on when done or use screws?
  14. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,247
    CT
    John Kreskovsky
    Black pop rivets were oe in '85. I also have a nos diaper. I call the finish satin or semi-flat. Very hard to find a high temp paint with is a good match.
  15. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    Black pop rivets on an '83 as well.
    This is what I used. I think it looks very close to OEM. It's a satin black.
    [​IMG][​IMG]
  16. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    405
    PA
    Alex
    I'm about to repaint my vents and diaper on my US '85. About those black pop rivets for the two fender grills... does anyone have the size and a source? Before I drill them out I want to make sure they are not some exotic size requiring an exotic rivet gun. Thanks.
  17. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    They are a readily available standard size, black finish, pop rivet. I can take a look at the box of left over rivets if you like when I get home this evening. I can't remember who I got them from right now, but I am sure there was another thread on this site about black pop rivets and where to get them.
  18. Alex308qv
    Jul 1, 2016
    405
    PA
    Alex
    I'd appreciate that, thanks. I found Carquest and McMasters mentioned as sources in my FChat search, but would like to know the correct rivet size and brand you used.
  19. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    I used aDP 1/8" rivets. 2 sizes of the length, better go use a slightly longer pop rivet, this ensures there is enough bite left, if it is too short, it may pull through at some time in the future. The minimum quantity I could get were boxes of 100 rivets, so I have a few left over. If you need some, pm me with an address and I can send you a few in the mail.
  20. Alex308qv
    Jul 1, 2016
    405
    PA
    Alex
    #20 Alex308qv, May 26, 2017
    Refinished mine recently. +1 on the Thermo-Tec #12001 Black High Heat Coating recommended in this thread... it came out excellent. $17.25/can on Amazon. I stripped the diaper inside and out (I'm a fan of Citristrip gel). Some areas required sanding where high heat turned the original coating enamel-like. Applied several coats following the instructions.
    Like most of us, heat changed the metallurgy of 2-3 louvers right in the center such that they rust and "exfoliate." I did my best to sand them smooth, and hope the Thermo-Tec protects them from further oxidation.
    Removed my louvered vents as well, stripped and blasted, and refinished them with the same paint. Used McMaster-Carr black 1/8" rivets, 0.4" long, #97526A130, $12 for box of 250 on Amazon. Length was correct.
  21. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    I painted mine with a felt tip marker... :)
  22. Alex308qv
    Jul 1, 2016
    405
    PA
    Alex
    By the way, and others know this I'm sure, stripping the cover reveals that it is made out of stainless steel. I'm not a fan of the affectionate (?) term "diaper" that is used for this cover. I would much prefer the affectionate term "BBQ grill cover," as it really looks like one when stripped, plus it covers something that is damn hot. I am going to start calling it that and see if it catches on.
