Rear Glove Box Won't Open | FerrariChat
Discussion in '360/430' started by Njja, Dec 25, 2011.
  1. Njja
    Njja Karting
    Oct 16, 2011
    57
    kennesaw
    JOHN ADIVARI
    Hi new owner here, my rear glove box won't open with the switch. When I picked up my 360 Spider my salesman told me this was a problem with this model. Does anyone know of a solution, or a method for opening the compartment to inspect the switch?
    I have read the manual which simply tells you how to open it using the console switch.
    Thanks for any advice.
  2. m.roberts
    m.roberts Formula Junior
    Nov 2, 2009
    907
    My 430 used to do this. I found that lightly pushing in on the box and rocking the switch would cause it to open after a few seconds
    robertjskelton likes this.
  3. D16RR
    D16RR Karting
    Nov 4, 2011
    168
    Florida
    Drew
    Mine does it too...sometimes I just push the rear box in a bit, then hit the switch and it opens really slowly.
    Now I just keep mine open all the time.
  4. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    I do not mean this in a negative way at all - just checking the basics. You have the car power on when you hit the switch to open the rear glove box? My car is not with me right now but I recall that you have to have the power on for these buttons to work.
    Also, your gas cap button is working ok (being in the same location)?
  5. Njja
    Njja Karting
    Oct 16, 2011
    57
    kennesaw
    JOHN ADIVARI
    Yes I tried to open it with the car running. Everything else, gas cap, hood release, and top
    works fine. My salesman told me the rear glove box was a problem so I posted my question with the hope that other owners might have resolved this issue.
    My 360 Spider is great but I like to have everything working on my vehicles. Thanks for your
    input, and I never take any offered help in a negative way.
  6. scubamike
    scubamike Formula Junior
    Nov 7, 2010
    323
    In the south
    Mine did that too occasionally. If it got stuck closed, I put something flat (like a thin comb) in the gap at the top and gently pried on it while pushing the switch that opens it.
  7. ttdang123
    Nov 28, 2009
    706
    North San Diego CA
    Tung
