430 - Rear Hatch Warning On After Installing Morimoto LED Tail Lights | FerrariChat
430 Rear Hatch Warning On After Installing Morimoto LED Tail Lights
Discussion in '360/430' started by RossoF430, Jul 13, 2023.
  1. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    As the title says, I just installed a new set of Morimoto tail lights and the rear hatch warning light and beeping noise started happening. Anyone else install these lights and had this happen?
  2. Qavion
    Qavion F1 World Champ
    14,350
    Ian Riddell
    I can't see an obvious connection.
    Maybe it's coincidence. Maybe your rear lid isn't latching properly or the microswitch has broken. See pic below:
    Thanks to @tomw for the photo.
    If you can find a plug or earth for the lid microswitch, disconnect either of those and it should simulate a lid closed (if I remember correctly).
    Did you disturb any earths (grounds) during the installation?
    Do you have a USA car?
    Do your brake lights actually work? If you've blown a brake light fuse, the car won't like that.
    tomw and mwstewart like this.
  3. fstbiker
    fstbiker Formula Junior
    Jun 28, 2012
    510
    New Jersey
    Did it happen as soon as you installed them? I have these lights and have driven a few times and no issues so far. I think the pressure switch is on the hood, so when you close it, it presses it together on a small silver square next to the latch.
  4. LorenzoR
    LorenzoR F1 Rookie
    I dont see any connection either. I think its just a coincidence.
  5. Qavion
    14,350
    Ian Riddell
    You may be thinking of the high stop light contact.
  6. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    Yes, it happened immediately after installation. Upon searching the interwebs, I found an article where a 430 owner changed his bulbs to LED bulbs and got the exact same issues that I am having. He removed the LED bulbs and went back to stock and the issue went away.
  7. fstbiker
    Jun 28, 2012
    510
    New Jersey
    Part Number 14 is the below. I think its names different things. I think that what shows the system the engine bonnet is closed . I could be wrong. I cant see the lights giving it issues, but its possible. Maybe swap back and see if your problem goes away.
    143331 SWITCH - ENGINE BONNET
  8. CoreyNJ
    CoreyNJ Formula 3
    2,476
    New Jersey Shore
    I would check the wiring you just plugged in. Do all the lights work? Does your 3rd brake light work? Is there "crud" on the contact points.
  9. Qavion
    14,350
    Ian Riddell
    The switch/contact is shown as XA47 in the wiring diagrams. It only provides power to the high stop light on the lid.
    It's not a switch in the true sense. It's just a contact.
    Will the contact indicate that your lid is open. Yes, if you push the brake pedal and someone behind you sees that your high stop light is not working.
  10. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    389
    Covington GA
    Tam V.
    I would plug the OE taillights back on to see if the error goes away, to confirm that the LED taillights is the cause.
  11. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    I did and the warning light/chime went away. It is definitely the LED lights causing it.
  12. LorenzoR
    LorenzoR F1 Rookie
    This is really weird. I have no issues and mine been on almost 2 weeks
  13. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    Just dawned on me, I have the Scud ing Swiss F1 bypass. How many of you are running this as well and not having any issues?
  14. LorenzoR
    LorenzoR F1 Rookie
    I do. no issues
  15. Qavion
    14,350
    Ian Riddell
    Can you isolate the problem to a particular side? With the L/R side or light cluster/s disconnected, do you still get the warning?
  16. fstbiker
    Jun 28, 2012
    510
    New Jersey
    F1 bypass? You mean ediff bypass?
  17. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    Yes, ediff bypass
  18. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    This is good to know that there is no conflict with the e-diff bypass. I am away on vacation for 3 weeks, I will resume troubleshooting when I return.
  19. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    I have contacted both Morimoto and The Lighting Guru (dealer I bought from) and they are researching the issue I am having. It is definitely the Morimoto system that is causing the error since reverting back to stock tail lights eliminates the error. Upon further research, I came across this older post which describes the exact same issue I am having. It is likely that one or both of the resistors supplied to me are defective.
    F430 - What's this red dash light mean? | Ferrari Life Forum
    Qavion likes this.
  20. Qavion
    14,350
    Ian Riddell
  21. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    At first I thought it was the lid warning light, but that is the exact warning light I am getting with these LED lights.
  22. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    380
    NC
    It’s probably detecting a P1760 (brake switch failure) if you scan codes on the TCU. I know of another 430 with the morimoto lights with this problem - was very intermittent though.
    Qavion likes this.
  23. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    I did some more testing this morning and installing the Morimoto on the left side (driver) with OEM taillights does not trigger this warning. It is only until after the right side is installed that the warning immediately comes up. I have been in constant communication with The Lighting Guru (dealer) and they are relaying the issue with Morimoto, but Morimoto has not provided a warranty solution and it has been almost one month.
  24. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    I'm going to close out this thread with a resolution to my issue. I remembered installing a first generation ScudIng Swiss led third brake light and that turned out to be the conflict. For some reason the car doesn't like the amp draw when the Morimoto tail lights are installed with the aftermarket led third brake light. I reinstalled the OEM third brake light and the error has disappeared. It is unfortunate that the third brake light is now much dimmer than the taillights. I hope this thread helps other members and make sure to consult with Stef or whomever you purchase an upgraded third brake light. So as it stand, the first generation ScudIng Swiss third brake light WILL NOT work with the Morimoto tail lights. Thank you all.
  25. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    Below is what I received from Stef:
    Thank you very much for your message.
    The problem is definitely not with our LED 3rd brake light but with the Morimoto lights that are missing an important element (very cheap Chinese R&D).
    The light you're having is an F1 error light (not a rear hatch open warning...).
    To correct what is missing in the Morimoto lights, you need to install this solution:
    NO-F1 FAILURE BRAKE LIGHT CONNECTION CABLE
    Our LED rear lights solutions integrate the above solution to avoid having the F1 error light !
    I hope this is helpful,
    Stef
    cavlino, Nero_Tenebre and Qavion like this.
