355 - Rear heat shield | FerrariChat
355 Rear heat shield
Discussion in '348/355' started by lanab, Sep 12, 2020.
  1. lanab
    lanab Formula Junior
    Feb 21, 2016
    516
    Stockholm, Sweden
    I have a question about the rear heat shield in front of the rear bumper, can you drive without it as mine is just trash when i removed it?
    How do you guys do it? is there some other way to protect the heat, can i insulate the exhaust silencer?
    I don't have the original setup anymore but the Nouvalari SS which is a smaller box, like Tubi.
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,632
    Elliott Caras
    Running without a heat shield is asking too much from the bumper and paint. I was sick of the tight fit with Capristo exhaust and the stock heat-shield so I made a custom one to protect my OEM heat-shield from damage.
    It’s a rigid alloy heat shield that can withstand and reflect extremely high temperatures. It was massively noticeable to the touch the difference of bumper temperature with and without a shield in place.
    308 GTB, [email protected] and lanab like this.
  3. Carmellini
    Carmellini Formula 3
    Jul 16, 2019
    1,008
    #3 Carmellini, Sep 12, 2020
    ^^^^ Looks great too....it that a generic sheet material? source? did you eliminate your OEM shield, or is this one placed over it?
    MAD828 and lanab like this.
  4. lanab
    Feb 21, 2016
    516
    Stockholm, Sweden
    That looks real clean and much better than original.
    Where did you source the heat material for this? i suspect you formed the heat shield to the old original mold to get the correct shape in the end?
    MAD828 likes this.
  5. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,632
    Elliott Caras
    It completely replaced the stock heatshield and does a much better job to boot. I sourced it from an eBay seller it’s DCI XT-1000 rated to 1000 degrees Celsius. It’s dimpled alloy like they use on turbo blankets and Tubi headers.
    It comes as a flat sheet I form rolled it to match the OEM curvature. Added the black line as per OEM. It’s totally reversible when I concours the car I swap back the exhaust and the stock heatshield.
    lanab likes this.
  6. Carmellini
    Jul 16, 2019
    1,008
    ^^^^thanks....do you remember the dimension of the sheet? how easy to form? about how thick?
  7. lanab
    Feb 21, 2016
    516
    Stockholm, Sweden
    The sellers ebay ad says 700x320mm, i measured my stock heat shield and it's 700x360mm so it's close.
  8. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,632
    Elliott Caras
    Correct it’s a bit shorter but does the job. You can rivet on longer lower brackets if you are so inclined.
    lanab likes this.
  9. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Nice job. Good info. Thank you.
  10. Carmellini
    Jul 16, 2019
    1,008
  11. Carmellini
    Jul 16, 2019
    1,008
    Can the muffler shield be removed/installed without removing the rear bumper?
  12. FourthAlfa
    FourthAlfa Karting
    184
    Paris, France
    Andrew Love
    I don’t think so, you won’t be able to get to the upper heat shield bolts.
    The rear bumper on the other hand is quite easy to take off (8 bolts and 3 electrical connectors)
    Qavion likes this.
  13. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,632
    Elliott Caras
    No it won’t come out without the bumper off.
  14. Carmellini
    Jul 16, 2019
    1,008
    ^^^^^^^ok, thanks.
  15. Carmellini
    Jul 16, 2019
    1,008
    I love the idea of protecting the rear bumper from excess heat and have seen a number of rear bumpers with spider cracks most likely caused by heat, but wonder if a better heat shield is a bad idea keeping more hot air in the engine bay? what do you think MAD828?
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Put on a challenge grill, the vacuum pulls the hot air out more efficiently.
  17. lanab
    Feb 21, 2016
    516
    Stockholm, Sweden
    You don't need the rear heat shield if you use the challenge grill?
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    No I would still have both it just cools the mega hot engine compartment better while moving
