Rear hub shaft removal | FerrariChat
Discussion in '206/246' started by russh, Sep 2, 2019.
  1. russh
    russh Karting
    146
    Northern California
    Russell Hazarian
    Hi, I currently do not have a shop/hydraulic press, and I am trying to determine if I can use a 10 ton hydraulic bench top press to remove the rear hub shaft from the pressed in bearings. I have very limited garage space to work in (one car garage) and was hoping that a 10 ton press would be sufficient to remove the shaft. I have no idea how much force it will take to remove it Image Unavailable, Please Login . Thank you. Russ
  2. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    I removed mine with a 10 ton press, I recall they came apart OK once moving. It might take more, take it to a good shop if concerned you’re at the limit of the press.
    The only part on a Dino I couldn’t do with a 10t press was the front steering control arms into the spindle, needed 50t.
  3. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    They normally come out quite easily once moving, would suggest spraying some release agent around the bearing/hub before you start
  4. russh
    russh Karting
    146
    Northern California
    Russell Hazarian
    Hi Andrew, thank you very much for that advice. I will search for a 10 ton bench press. I'll save the front steering control arms into the spindle for someone else to do.
    I will try using a release agent prior to attempting to press out the shaft. Thank you.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,553
    San Carlos, CA
    Mitchell Le
    Russ
    where are you in NoCal?
  6. russh
    russh Karting
    146
    Northern California
    Russell Hazarian
    Mitchell, I am located in the Walnut Creek/Concord area.
  7. yelcab
    Nov 29, 2001
    13,553
    San Carlos, CA
    Mitchell Le
    Try it with your bench top press but I don't think that will do it. If it does not, bring it to my place and I can do it for you, or I can put you in touch with someone on the East Bay with a larger press.
  8. russh
    russh Karting
    146
    Northern California
    Russell Hazarian
    Thank you, I really aprreicate it. I will definitely get in touch with you if I am unsuccessful in pressing it out.
