Rear inner boot panel fixing | FerrariChat
Discussion in '206/246' started by snowsports1, Jan 3, 2015.
  1. snowsports1
    snowsports1 Formula Junior
    Jan 31, 2013
    918
    Brian
    Hi, does anyone know if the extra long studs on the rear lamps intended to come through the rear plastic panel to fix it?
  2. Nuvolari
    Nuvolari F1 Veteran Owner Silver Subscribed
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    No. The M3 studs should terminate before the inner plastic panel. The only holes that should be on the plastic panel are the ones that fix the panel to the chassis. In my case I had 3 original screws doing this although I have seen up to 5 but cannot comment if they were added later or not.
  3. snowsports1
    Jan 31, 2013
    918
    Brian
    Thanks, I wonder why I have two long M3 studs + 1 super long stud (probably 50mm long) for each original rear lamp?
  4. jvj
    jvj Rookie
    Sep 18, 2009
    48
    South Australia
    Vince
    Rob, 3 original screws also on 01616 GT rhd
    Vince
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Vendors call the rear interior vertical plastic piece a "batchboard"
    Are you saying three slot screws attach the batchboard to the gutter rail?
    This would be similar to the front spare tire batchboard's four gutter rail screws
  6. Nuvolari
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    Three screws fit the batchboard to the tube structure on the inside back of the trunk assembly. The screws do not go along the gutter rail like in the spare tire area.
  7. snowsports1
    Jan 31, 2013
    918
    Brian
