Rear Latch Issue | FerrariChat
Rear Latch Issue
Discussion in '360/430' started by Albertinir, Jun 3, 2021.
  1. Albertinir
    Albertinir Rookie
    Aug 1, 2018
    2
    Rick A
    So my rear latch suddenly stopped working, wont close and of course wont go into gear. Any troubleshooting tips.
  2. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    Do you mean physically cannot latch or it does latch but the dash shows the latch is open and therefore can't engage the gear?
  3. timwu12
    Oct 31, 2014
    918
    TX
    If you can't physically latch it shut, open up the latch box cover (there's like 4 small screws) then adjust the cylindrical cable pull lock to give it a bit more slack and it should work.
    If you can latch it but the light on the dash shows it's still open then you need to bend the metal flap on the microswitch a bit so that it engages the switch better. This microswitch is also under the latch box cover.
  4. Qavion
    Qavion F1 World Champ
    14,297
    Ian Riddell
    How tight are the nuts on the striker plate on the engine lid? Sometimes the adjustment nuts work loose and the lid doesn't sit properly. On this type of mechanism, there may be nuts on both sides of the striker plate.
    E60 M5 likes this.
