Rear light stays on! Help! | FerrariChat
Discussion in '458 Italia/488/F8' started by Fabiolous89, Dec 14, 2024.
  1. Fabiolous89
    Fabiolous89 Rookie
    Nov 22, 2024
    25
    Hey guys, so this morning out of no where the rear center light stays on, I checked all the doors etc Eveyrhing is shut! Any idea what’s going on??
    picture below!
  2. Trev450
    Trev450 Formula Junior
    Mar 11, 2024
    558
    Trevor H
    Are the other 2 brake lights on as well?
  3. Fabiolous89
    Fabiolous89 Rookie
    Nov 22, 2024
    25
    No they are not.
  4. Trev450
    Mar 11, 2024
    558
    Trevor H
    You could try doing a reset by disconnecting the battery for 15 minutes.
  5. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,718
    France
    In my vague memories it could be caused by some moisture - maybe if it's the case, gently warming the lights may solve the problem (this is purely hypothetical).
  6. Snapshift
    Snapshift Formula Junior
    900
    Centralia IL
    Lyle D. Pahnke
    Make sure the contact pin isn't stuck makes good contact etc. there is also a module attached to the light under the bonnet lid may be faulty
  7. Fabiolous89
    Fabiolous89 Rookie
    Nov 22, 2024
    25
    The only thing I did this morning was drill out the rivets to replace the leather straps in the frunk this morning. Could I of hit any wiring that would cause this?
  8. Fabiolous89
    Fabiolous89 Rookie
    Nov 22, 2024
    25
    tried disconnecting the battery already.
    Trev450 likes this.
  9. Fabiolous89
    Fabiolous89 Rookie
    Nov 22, 2024
    25
    So there’s 2 of these that get pressed down once the frunk is closed. If you push them both down at the same time… should the frunk lights go off?
    thanks
  10. Snapshift
    900
    Centralia IL
    Lyle D. Pahnke
    See if brake pedal switch is sticking.
  11. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,369
    AUSTRALIA
    ANGELO
    For your information , I discovered way back in 2018 that these lights are ALLWAYS ON. No matter if the car is locked or unlocked , alarm on or alarm off.
    I noticed it when I went in to see the car and it was dark.
    This is evident on ALL the cars with these 3rd brake lights. 488 , PISTA , F8's
    However, yours are highly illuminated. I would look at the brake switch.
    BTW pointed it out to the Ferrari Techs back in 2018 and FERRARI never replied even though I have complained every year on every free service ( I wanted this documented )
    IMO ALWAYS have the tender on when not driving because believe it or not your car does drain the battery when standing. :(
