Just refitting the rear lights and noticed - upon closer inspection - 3 out of the 4 Carello bulb holders are cracked/chipped. I see S/Formance appear to have these - small image below; "Rear Indicator Wiring 246 24619155 £12.95" - I guess one get the plastic ends with the wiring, which is what I need. Anyone care to confirm these are a suitable replacement, or that you've used them and they will fit the lenses etc: Or...is there a more suitable part/supplier. Thanks in anticipation, Paul. Image Unavailable, Please Login Image Unavailable, Please Login
I have bought these - they fitted fine. You get the bulb holder and the wiring but you need to take the connector plug from your old one and fit to the new one, which is easy to do but you will need new 'long' copper spade connectors. I bought these from a company that sells this sort of thing to kit car builders (Terminals and Connectors - Car Builder Solutions - Kit Car Parts and Accessories). You will also need new rubber caps if yours are perished. You can buy these from Cigognani in Italy (see item 16326258 on this page Dino 246 GTS (1972-74)).
