348 - Rear Lower control arm dimension | FerrariChat
348 Rear Lower control arm dimension
Discussion in '348/355' started by steved033, Dec 10, 2020.
  1. steved033
    steved033 F1 World Champ Owner Silver Subscribed
    Apr 12, 2017
    10,174
    Atlanta, GA
    Steve D.
  2. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    I measure 345 mm
    steved033 likes this.
  3. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,538
    Jeff
  4. steved033
    Apr 12, 2017
    10,174
    Atlanta, GA
    Steve D.
    I've got a WSM, and just wasn't able to get into the garage and measure for myself today. the WSM doesn't have that dim.
    Basically, I've got rear dims from my alignment, and "the place to go to" didn't want to wank around with doing and undoing shims, so they basically set the toe, and sent me on my way. The dims read in such a way that if pull a toe shim from one side and put it on the other, it should even things out....NOW, (in my brain) I need to make a quick CAD model of it in order to do so.
    UNLESS, of course, one of you knows that a 2mm shim is = to .xx degrees of toe. I'm literally looking to move .2 degrees out on the drivers side, and .2 in on the passenger.
    sjd
  5. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,538
    Jeff
  6. m.stojanovic
    m.stojanovic F1 Rookie Silver Subscribed
    Dec 22, 2011
    3,282
    Serbia - Niš
    Miroljub Stojanovic
    You already have the info from John and Jeff, it is 345 mm. Using the drawing shown in the manual (as also posted by Jeff) showing the 288.5 mm dimension and extrapolating it (scaling) to the dimension you need, I got 347 mm. As my ruler is not 100% accurate, I would take 345 mm as correct.
  7. steved033
    Apr 12, 2017
    10,174
    Atlanta, GA
    Steve D.
    ricambi has them too.
    The model tells me that 1mm shim is good for about .17 degrees of toe. It's also shown me that I need to move 1mm of shim from the left to the right.
    sjd
  8. Ferrarium
    Ferrarium F1 Veteran Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I had 1mm shim is .5 degree from a old Mitch Alsup thread.
  9. m.stojanovic
    Dec 22, 2011
    3,282
    Serbia - Niš
    Miroljub Stojanovic
    My calculation shows 0.166 Deg. per 1 mm shim. If 1 mm is added (or removed) at one point of the lower arm, the other point is the centre of rotation around a horizontal circle having 345 mm radius, thus:
    Circumference of the circle: 2*345*3.1415926535 = 2,167.70 mm
    Angle change per mm of shim: 360 / 2,167.70 = 0.166 Deg.
  10. steved033
    Apr 12, 2017
    10,174
    Atlanta, GA
    Steve D.
    That's how I did it, just more graphically. My measured toe is .4 degrees on the left and .07 on the right. 1mm shim should move things as such: .4 - .166 = .234 .07 + .166 = .236
    ...this is also not at loaded spec.
    sjd
