Rear Screen | FerrariChat
Rear Screen
Discussion in '206/246' started by possum, Jul 16, 2009.
  1. possum
    possum Formula Junior
    Sep 27, 2008
    307
    australia
    johnno
    Has anybody purchased or know some one who has purchased a Rear screen from Dino parts,their cost is $1160 US.Do these screens fit ok or what has been your experience would like some help before I hand over the $s
  2. Dino Club Germany
    Dino Club Germany Formula Junior
    Nov 10, 2008
    549
    Germany
    N. Schumacher
    I heard that some rear screens broke during mounting.
    Reason seems to be not flexibel enough glass, when you need to push both ends together while assembly.
    But it is just something I heard, I have no real facts..
    What about the other guy who wanted to reproduce rear screens, he seems to be quite experienced?
  3. possum
    Sep 27, 2008
    307
    australia
    johnno
    He is still waiting on sufficient numbers set up is around $10000 thanks for your input hopefully get some more replies
  4. racerboy9
    racerboy9 F1 Rookie
    2,642
    Got my NOS rear windscreen in today (WHEW WAS I LUCKY!!!). If any measurements are needed I can take them before I install it. Will be putting it in this Sunday.
  5. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Indeed, one must compress the two ends towards the middle by about 1 to 2 cm to clear the buttresses. I have done it 3 times without difficulty. Silicon on the ends of the rubber seal where they rub against the buttress while sliding the glass into position is strongly recommended by this observer. Once set into place at the pinch rail and beyond the butresses, final insertion with a pull-cord in the goove of the rubber seal is a breeze.
    Jim S.
  6. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,487
    Germany
    Matthias
    #7 GermanDino, Jul 22, 2009
  7. racerboy9
    racerboy9 F1 Rookie
    2,642
    Aren't these the ones made by SICURVETRO, a Scandinavian country? Would these be the same sold by Dino.de?
  8. possum
    Sep 27, 2008
    307
    australia
    johnno
    I would appreciate some measurements,the height of the middle of the screen and the inside measurement from tip to tip across the screen if this makes sense.
  9. racerboy9
    racerboy9 F1 Rookie
    2,642
    I will get those measurements for you this weekend. If buying a reproduction glass the dimensions need to be very close to the original or it will never sit correctly in the car. That tip to tip measurement being the most crucial. When I took my windscreen out, I pushed the rubber lip over the metal from inside the car all the way around. Then with my helper I started pushing one end out first and the whole window came out in a hinge fashion with almost no effort or stress on the glass. I was thinking of reinstalling it the same way so as to minimize stress on the glass. Dennis McCann said that is the way he put them in. Is this the way you put your in Jim S.?
  10. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    I took a razor blade to my seal and made a circumferential incision all the way around, thereby destroying the seal. The glass came out easily without the rubber on it. Plenty of room. Each of my installations were related to complete restorations, hence a new seal was in order.
    However, when reinstalled, I placed the new rubber on the glass first, along with the pull-cord in the groove. With the rubber seal on the glass it is a tight fit past the buttresses. Slight pressure and a bit of silicone on the end points (where they rub past the butttress) and the glass found its way to the pinch rail for final insertion. It takes two (or three) people, of course. One to press gently on the outside in, while one person sits within the car and pulls the cord perpendicular to the glass. The outside pressure follows the cord and vice versa (the cord puller works with the pressure to pull where the pressure is). A plastic "tongue-depressor" or spoon helps to lift the rubber over the pinch rail.
    Just go slow, work it, and don't be afraid to start over if things slip out of place. Suction cups help A GREAT DEAL. Find a pair and it will make your life a great deal easier.
    Jim S.
  11. racerboy9
    racerboy9 F1 Rookie
    2,642
    Did you go straight forward with the glass square to the car with no angling of the glass.
  12. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    It came out rather easily (with the rubber cut off and remaining on the pinch rail). Square out, but you will not have any difficulty moving it about to remove from the car. However, when installing it in the car with rubber around the glass, it will not go square in. You must put one end in first, and then gently press the other end past the buttress. The first end to enter should be pressed as deeply into the opening as possible. In fact, if you can get the seal to sit on the pinch rail of this first-end-in you will get more clearance. Then you swing the other end in. This is where the silicone past or spray will help.. It keeps the rubber from impeding the movement of the end past the buttress.
    This will become evident when you do it. It really is rather easy. Just go slow.
    Jim S.
  13. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Racerboy - just had a thought.
    The reason that you must install the window with the rubber seal on the glass relates to the chrome surround. Once the window is in the car, you cannot install the surround. It must be placed in the groove of the rubber seal while the window is out of the car. Hence, insertion of the window must take place with the rubber seal and surround installed on the glass.
    Jim S.
  14. possum
    Sep 27, 2008
    307
    australia
    johnno
    Does anybody have a contact in Italy that could make contact with Dino Parts and get some dimensions on their rear screen,the measurement across the width at the tips where it narrows is critical,I have been unable recently to make contact with them to get this info.
  15. racerboy9
    racerboy9 F1 Rookie
    2,642
    Possum,
    I will get those measurements today. I went to the beach and totally forgot about it.
  16. racerboy9
    racerboy9 F1 Rookie
    2,642
    The overall width of the rear screen is 39" on the button. That is outside tip to outside tip. The height at the center is 8.5". If you need any other measurements please let me know.
  17. possum
    Sep 27, 2008
    307
    australia
    johnno
    Thanks racerboy that is great the measurement from Dino parts is 999mm 39.3306 inches,I will keep you posted on my decision.
  18. racerboy9
    racerboy9 F1 Rookie
    2,642
    That is over 1/4" wider overall or 1/8" on each end. That may work OK but it is hard to say. If they have several I would have them measure them all and get the one closest to 39". S.Gobain made thousands for the Dino and in all likelyhood they weren't all exactly the same. I would guess they would have an acceptable tolerance range.
  19. BigTex
    79,368
    Houston, Texas
    Bubba
    I think there are some plexiglass repros, if cost is a consideration????
  20. StephenShoubridge
    May 28, 2006
    102
    West Sussex UK
    Stephen Shoubridge
    Mike who did my bodywork has a spare original one would you like me to ask if he would sell it
    not sure if he uses it as a template for when he is restoring them.
    Regards
    Stephen
  21. possum
    Sep 27, 2008
    307
    australia
    johnno
    That would be great stephen I will hold of ordering one until I hear from you.
  22. sicurvetro
    sicurvetro Rookie
    Mar 23, 2006
    12
    Hi,
    As promised to many, we have finally entered production with the TEMPERED/TOUGHENED Dino 246 REAR SCREENS!!!
    As many have said before, laminated ones do not work for 'obvious' reasons. Period.
    (we've never done the laminated ones before, as we soon found out they would not work!)
    As a sample, we are using an original glass.
    It is one of four OEM-glasses we compared at Peter Julin's garage in Stockholm earlier this spring. All 4 were slightly different (by a few mm's), although they were from the same original producer. The small variations could have come from the process/the way they were done; they could have given in a little at tempering-process in the oven (after bending-oven), or they might have used several toolings/molds when making them originally with slight differences to the molds or the cure-time in/out the ovens etc...
    Anyhow, we chose the one that was in between the four and also tried and measured it carefully on the 4 cars there; it was the best specimen of the 4 to use, although they all would have worked well, though;
    -tempered glass bends slightly, and thus allows a small amount of play with the tolerances, which is well needed with the Dino 246 rear-glass installation; no 2 Dinos are 100% identical there... ...
    Delivery-time will be in late June to early July, ex works here in Finland. Delivery by air to even furthest locations takes only a few days. By sea; i.ex. USA, about 6-8 weeks, EU about 1 week.
    At the moment we are trying to find the most suitable way to distribute this one initial batch worldwide (thay are done in larger batches only, not individually!).
    -The more we can pack in one crate/destination, the less the freight etc. costs per glass will be (shipping a single glass to i.ex. USA is relatively expensive).
    If anyone has any good suggestions, please let me know, or give me a call here!
    Pricing and terms given by private mail!
    yours from finally sunny Finland,
    Antti Wihanto
    Wihanto Trading / parabrezza SICURVETRO
    Allinkatu 13
    20100 Turku
    Finland
    ph. +358-40-551 9841 (+2 hrs to GMT, +10 to PST), 7 days ok to call!
    ('70 246 GT)
    www.sicurvetro.com
    www.concours.fi
  23. possum
    Sep 27, 2008
    307
    australia
    johnno
    Hi Antti,have you had any luck finding a distributor for your screens?
  24. DinoLasse
    DinoLasse Formula Junior
    606
    Sweden
    Lars
    Possum - and anybody else interested in rear screens or other specialty glass from Sicurvetro:
    I have been in contact with Antti about acting as a distributor for their products. I am willing to order a crate with screens and import them to my office in Chicago. From there, they can be shipped out at a reasonable cost. Once the first batch is delivered, I will keep some some pieces in stock for immediate delivery.
    Please email or PM me with your interest. I have to order a substantial minimum quantity from Sicurvetro to get this started, so it is important to know how many of you are interested.
    Lars
