Rear seat back removal | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Theruse, Jul 27, 2023.
  1. Theruse
    Theruse Karting
    Jan 17, 2014
    179
    Maryland
    Prescott Russo
    I am trying to remove the rear seats.on my 1978 400 The seat bottoms were not a problem once I figured out that they are secured by a few bolts. I tried to take out the seat back and removed the screws at the base of the seat but was not able to remove the seat. I did not want to force the issue, but is there another screw or bolt that secures the top of the back seat top?
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    2,306
    Lyon (FR)
    R. Emin
    You slide the seats up. It does require some persuasion...
  3. Theruse
    Theruse Karting
    Jan 17, 2014
    179
    Maryland
    Prescott Russo
    Thanks. Now I feel more confident to pull it up. I was surprised with the seat bottom as most current cars you can just pull up. When it wouldn't budge I ran a mirror underneath and saw the two bolts.
    Ak Jim likes this.
  4.
  5. Assuming they are the same as the 412., I recall there are two bolts on the back of the seats that are accessible from the rear wall of the trunk,
  6. Jim575
    Jim575 Karting
    Sep 26, 2011
    174
    Sydney Australia
    Jim K
    There are 3 screws at the bottom, don't forget the centre one, then you slide the rear (squab) backrest upwards.
    Jim
  7. Theruse
    Theruse Karting
    Jan 17, 2014
    179
    Maryland
    Prescott Russo
    Thanks. I will check the trunk and see if there are bolts on the Series 1 400's. Don't recall if there were two or three bolts at the bottom of the back and will check.
  8. Jim575
    Jim575 Karting
    Sep 26, 2011
    174
    Sydney Australia
    Jim K
    Hello
    No bolts in the trunk on a series 1 car, just 1 screw each side of the rear squab and 1 up high in the centre of the rear squab.
    Jim
  9. Theruse
    Theruse Karting
    Jan 17, 2014
    179
    Maryland
    Prescott Russo
    Since you mention the screw is up high at the center, I am assuming the only way to loosen this screw is through the boot.
  10. Jim575
    Jim575 Karting
    Sep 26, 2011
    174
    Sydney Australia
    Jim K
    Under the centre squab section there is a bucket and the screw is on the cabin side, not the boot side.
    It should be a Phillips head screw.
  11. Jim575
    Jim575 Karting
    Sep 26, 2011
    174
    Sydney Australia
    Jim K
    There is a bracket, the screw is in the centre of the bracket, cabin side.
