Rear Shock Absorbers | FerrariChat
Discussion in '348/355' started by 355 Shwing, Mar 21, 2016.
  1. 355 Shwing
    355 Shwing Karting
    Sep 9, 2009
    157
    Gulf Breeze, Fl
    Craig Payette
    Hi All,
    I'm looking to upgrade my rear shocks. Does anyone know of such an upgrade?
  2. albagtp
    albagtp Karting Silver Subscribed
    Sep 23, 2014
    57
    Beach City
    Bryan
    It would be worth talking to Rob at Delta Vee Motorsports in Kallamazoo Mich.
    He is one of the best versed with 348 and 355 Shocks around. He may be able to revalve your existing ones.
    Good luck, Bryan.
  3. 355 Shwing
    355 Shwing Karting
    Sep 9, 2009
    157
    Gulf Breeze, Fl
    Craig Payette
    Yea,
    I am considering using him, but I was just wondering if there is a better aftermarket Shock out there instead of re-doing the existing shocks.
  4. Yassa
    Yassa Formula 3 Silver Subscribed
    May 23, 2011
    1,266
    London
    Dr Yassa Hughes
    There are a few options but they are not cheap,
    Nitron, Moton, Öhlins...
    Depends on budget, taste and requirements.
  5. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    It all depends on the cars intended use.
    Are you going to track the car or just drive it on the street.
    Is there a problem with the shocks currently....ie leaking?
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,727
    What performance aspect are you trying to improve ?
    Which car are you trying to improve it upon?
    Also note: one of the reasons the rear end is soft is to avoid snap oversteer under power application.
  7. 355 Shwing
    355 Shwing Karting
    Sep 9, 2009
    157
    Gulf Breeze, Fl
    Craig Payette
    One of them is starting to leak. Just like anything else in life, newer technology tends to be better than 21 yr old tech. So, I was looking to go with the newer tech. The re-build option requires my car to wait 6 weeks for turn around, so that's really not an option anymore.
  8. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,044
    I'd find some used ones on Ebay or something, send those out for rebuilding and then swap on your car. With rising values, it pays to keep the car oem looking and not use aftermarket parts which detract when selling.
  9. Mitch Alsup
    Nov 4, 2003
    9,727
    If you had them rebuilt, you could specify a slightly thicker oil and get higher rebound and compression dampings.
    Slightly should be between 10% thicker and 15% thicker. Any more and you start needing different springs or you get the chassis reactions of an overdamped car.
  10. Rifledriver
    37,099
    Robs advice would still be best.
    The 355 CH used unmodified shocks. They used the std 355 rear shock at both ends with a revised Bilstien control unit.
