rear shock actuators | FerrariChat
Discussion in '348/355' started by dwwis, Apr 17, 2016.
  1. dwwis
    dwwis Karting
    Oct 19, 2015
    68
    South Milwaukee Wi.
    Dennis Wesley
    question for you
    when reinstalling actuators what position is the dial on shock when switch is in sport position
    full clockwise or full counter clockwise
  2. Qavion
    Qavion F1 World Champ
    14,334
    Ian Riddell
  3. dwwis
    dwwis Karting
    Oct 19, 2015
    68
    South Milwaukee Wi.
    Dennis Wesley
    ok thanks
    I didn't know that
  4. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    Just FYI and to answer the original question.
    Anti-clock wise = harder compression.
    Clock wise = soft compression.
    Bought a new set of OE Bilsteins and checked first hand. There was a big difference in the amount of force needed to compress while anti clock, compared to the units at clock wise.
  5. dwwis
    dwwis Karting
    Oct 19, 2015
    68
    South Milwaukee Wi.
    Dennis Wesley
    suspension light still on
    I checked the actuators all four working fine
    any way to reset without taking to dealership
    they are to busy with services cant get me in for a month
    rear shocks rebuilt by delta vee
  6. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Two things.
    First try resetting your battery.
    Second. There are two suspension lights of your dash. Are you sure you have not flipped your suspension switch to soft via the switch to the right of your gear stick? Flicked one way (soft) and the light comes on, flicked to hard the light goes of. That could be the light your seeing especially if your new to the 355.
  7. dwwis
    dwwis Karting
    Oct 19, 2015
    68
    South Milwaukee Wi.
    Dennis Wesley
    i did the battery reset
    and it is the suspension light on the right side of the dash pod
  8. WATSON
    23,710
    WI
    Remember, if you start the car, or turn the key to position II, three or more times without moving the car, the suspension light will come on. ECU thinks the car started but did not receive any feedback from any sensors. Three times of that and the suspension light comes on.
    Fire the car up and drive about 100' and the light will go out.
    May, or may not, be your problem.
  9. Rifledriver
    37,114
    The reset happens every single time you turn on the key. If you have a light you have a current system failure.
  10. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    ^^^^This^^^^
  11. WATSON
    23,710
    WI
    Not true if you start and stop the car 3+ times and don't move it. Fourth try will trigger a suspension light when, in fact, all sensors may be fine.
    Been there. Done that.
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Me too.
  13. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    yea mine does this to, always has. After a few ignition starts the light then stays on, then i turn it of and on again and drive a couple of meters and the light does not stay on.
  14. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,319
    Southern New Jersey Shore
    Phil
    Make sure your actuators are seated all the way on the shocks, and that the retainer "clamp" is installed correctly. Front ones are tougher to seat on the shocks, especially if you have big hands.
  15. Qavion
    14,334
    Ian Riddell
