Rear side window stuck in UP position | FerrariChat
Discussion in 'Mondial' started by Roc, Jul 2, 2015.
  1. Roc
    Roc Karting
    Nov 19, 2013
    189
    Las Vegas, NV
    Rocco LaBriola
    My search showed how to fix rear windows that are stuck in the down position, but not in the up position. I plan to change out the motors or go to the Volvo regulator fix. How do I remove the window when it's stuck in the up position? Thank you in advance!
  2. bigeasy
    bigeasy Formula Junior
    Dec 31, 2012
    368
    Roc,
    what year, make and Model are you dealing with? On my 84 Mondial Cab. the rear side windows removed very easily, there just held in place by a thick caulk like material that will allow you to gently rock the glass back and forth while pulling upward, should pull right out with minimal effort, at least mine did. I had my original motors rebuilt for under 300.00
    Good Luck
    P.S. be glad it stuck while fully up if you plan on removing the window Motor!
  3. Roc
    Roc Karting
    Nov 19, 2013
    189
    Las Vegas, NV
    Rocco LaBriola
    Thanks Mark! Mine is an '85 QV Cab. I'll give it a removal shot this afternoon and report back!
  4. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    I think if you start removing inner panels, you will get to the regulator and possibly pry off the glass. Mine was stuck down but its the same effort. I will try to get back to this project before Labor Day !
    Check out my thread: http://www.ferrarichat.com/forum/141095411-post14.html
    Best,
