Rear suspension bolt needed 1965 330 GT 2+2 Series 1 interim car | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by AEB, Jun 23, 2018.
  1. AEB
    AEB Rookie
    Nov 11, 2016
    15
    new jersey
    art becker
    I am in need of the rear suspension upper radius arm bushing attachment bolt. The bolt fixes the forward bushing of the upper radius arm to the frame forward leaf spring bracket. The bolt is 14mm diameter and the thread is 14mm 1.5. The overall length of the bolt is 4.5 inches. Thank you
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I have a couple from an old Fiat that measure about 4" total length.
    This size (14 x 1.5 x 120) appears to be easily available online.
    If you have a local fastener supply outlet, they should have them on the shelf.
  3. TTR
    TTR F1 Veteran
    5,890
    Riverside, CA
    Timo
    Please be aware that bolt or hex screw length is indicated as the length of the (14mm dia.) shank only and also in millimeters (not inches).
    Head height/length is not included. So your OEM bolt might be M14-1.5 x 105, which is not "standard" or commonly available length, but either 110mm or 120mm long should work fine and can be cut to length if too long. You may also want to make sure the strength is at least "8.8" or higher.
    turbo-joe and BMWairhead like this.
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,526
    romano schwabel
    M 14 x 1.5 is not "normal" thread, it is fine thread and not very common. the normal thread is 1,75
    14 mm diameter is not common in 8.8, more 10.9
  5. TTR
    TTR F1 Veteran
    5,890
    Riverside, CA
    Timo
    Art, check out McMaster-Carr online catalog for #91180A802. It might work.
  6. AEB
    AEB Rookie
    Nov 11, 2016
    15
    new jersey
    art becker
    Thank you to everyone for the helpful input. I appreciate it. I am interested in pursuing an original (previously used) bolt from a 330 salvage. If anyone knows who may have one and how I could contact them please reply. If a used bolt is not available I will go for a modern replacement. Thanks.
    lancia likes this.
  7. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    No one can see it. I would think that a new one is safer than an old one if the new one fits.
