Rear Suspension Rebuild Question | FerrariChat
Discussion in 'Technical Q&A' started by seschroeder, Feb 21, 2004.
  1. seschroeder
    seschroeder Formula Junior
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    Well, the suspension rebuild continues to move right along. The rear is apart, parts out getting cleaned and power-coated, and the required parts in hand or on order. I'm replacing the inner bushings (using ES), shocks, and outer bushings. The outer (hub carrier) bushings (# 4 on parts diagram) are being replaced, inner bushing (# 8), teflon coated washers (# 9) , and all rubber seals #'s 6 and 7). The chromed cylindrical inner bushings (# 11) all show no appreciable wear and the chrome is intact.
    Now to the questions: when inserting the outer bushings into the "A" frames my bet is that it is best to have the inner bushings inserted into the outer bushing. Correct? Second, will the inner bushings require honing/reaming before the inner cylindrical bushings will fit? Finally, another "secrets" to doing this or is it fairly straight forward?
    As always, thanks in advance for the help and advice.
    Steve Schroeder
  2. Bob308GTS
    Bob308GTS Formula 3
    Sep 26, 2001
    1,150
    Aurora,IL
    Bob Campen
    Do press #8 bushing into #4 , before pressing #4 into a-frame
