348 - Rear suspension | FerrariChat
348 Rear suspension
Discussion in '348/355' started by John Glen, May 2, 2020.
  1. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    479
    Victoria, B.C, Can.
    John Glen Wesanko
    I have a 348 ts and presently have the engine out for maintenance. I have purchased a bushing kit for the rear suspension mounting points. What is the best way to unload the suspension to make disassembly less difficult ? Should I unwind the spring mounts to release pressure or is there a preferable method ? Thanks in advance, JGW
  2. A348W
    A348W Formula 3
    Jun 28, 2017
    1,749
    North Wiltshire, UK
    From memory not necessary. You can take them out as is.
    Hope you have a press? Bushes are a hateful job otherwise!
  3. John Glen
    Dec 30, 2009
    479
    Victoria, B.C, Can.
    John Glen Wesanko
    I knocked out a lower shock bolt with a brass drift, but now the drift is pinched. I was thinking of relieving the pressure by winding down the spring purchases ? Are the drive shafts limiting the bottom suspension travel ?
  4. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,792
    Atlanta, GA
    Steve D.
    You just undo the 4 top bolts and the whole thing should drop down as a unit. The lower bolt is also the sway bar endlink. I"m not sure how you got the drift pinched.
    QSA likes this.
