Rear "Tapping Sound" on 360! Help! | FerrariChat
Discussion in 'Technical Q&A' started by Jimmy540i, May 18, 2006.
  1. Jimmy540i
    Jimmy540i Formula 3
    2,494
    Los Angeles / NYC
    www.Jimmy540i.com
    Guys, my car (360 modena coupe) makes random tapping sounds (from the back I believe) while doing about 70mph + on the highway... the sound only happens when cars is on rougher pavement
    It sounds like something is loose but I've checked the glove compartments, seats & seat belt brackets and I can't find the cause...
    Any idea would help!
    Regards,
    Jimmy
  2. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    Is this the same issue you had after the major?
  3. Jimmy540i
    Jimmy540i Formula 3
    2,494
    Los Angeles / NYC
    www.Jimmy540i.com
    no, that was on my red 360, the tapping if from the engine and it does up and down with the RPM, it was fixed by FOC, it appears to be dusts in one of the intake
    this tapping on my yellow 360 sounds like something tapping against eachother while the car goes through rough surfaces, i'm 99.9% sure this is a non-engine issue
    any thoughts on this one?
  4. Martin Meade
    Martin Meade Karting
    229
    B'ham, WA
    Martin Meade
    Aftermarket floating rotors?
  5. ROLOcr
    ROLOcr Formula Junior
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    we just had a similar problem on a 360 and it turned out to be a bad ball joint on the rear suspension arm for the rear rigth tire, thae one the is bolted to hte chasis(don't know the correct name in english just in spanish)
