Rear trunk lid gasket | FerrariChat
Discussion in '206/246' started by UroTrash, May 29, 2011.
  1. UroTrash
    Jan 20, 2004
    40,476
    Purgatory
    Clifford Gunboat
    #1 UroTrash, May 29, 2011
    Am I supposed to have a rubber gasket on the underside of the rear edge of the rear trunk, where it sits on the 2 bumpers? Thanks!
    Sorry for the poor pic/graphic.
  2. UroTrash
    Jan 20, 2004
    40,476
    Purgatory
    Clifford Gunboat
    YooHoo....
  3. vrooom
    vrooom Formula Junior
    Jan 29, 2007
    457
    yes,will keep alot of the exhaust from the trunk. mine did not have when i got my car and did not want to put anything back there, the seal made a big difference.
  4. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    Does it go across the entire rear lip -- is it placed so that it is compressed by the two hard lid bump stops when you shut the trunk or is it's length between the two bump stops.
  5. vrooom
    Jan 29, 2007
    457
    runs full width of trunk. my car does not have the bump stops, it's a 73 gts.
  6. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,330
    Iain
    #6 isuk, May 30, 2011
    Can anyone post a pic of this seal or advise where (or even if) it can be bought from?
  7. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    #7 MarkT, May 30, 2011
  8. HMB-Dino
    HMB-Dino Formula 3
    2,281
    Pebble Beach, CA
    RonG
    It would be great if Matthias could chime in on this one regarding whether the rubber seal was standard and if so, for all years or just specific ones. My 71 Euro does not have this upper seal, nor any sign that one ever existed. My Dino, however, does have the rubber stops on the body. It would seem that the rubber seal on the body is intended to seal against the trunk lid when closed...seems uncharacteristic to have one rubber seal mating with another rubber seal.
  9. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    #9 celestialcoop, May 30, 2011
    Here's a source in Sacramento, California.
    Ferr Parts Inc.
    888-383-8444 or 916-974-1939
    [email protected]
    http://www.ferraripartsexchange.com/246GTRubber.htm
    No. 23, below, Upper trunk seal (The piece is shown upside-down in the schematic; see Mark's pictures, above, for clarification.).
    On my Tipo E, it goes across the back of the trunk lid and stops just short of either edge of the lid so as to be tangent to the side trunk seals (No. 8) while compressing against the vinyl edge seal (No. 16) when the lid is closed. It is glued just forward of the 'bumpers' (No. 15), so doesn't touch 'em.
    NO./ DESCRIPTION/ QTY OR LENGTH /PRICE
    3 "T" section seal 6 $36.00
    4 Outer door seal 10 $37.50
    5 Inner door seal (GT only) 24 $137.76
    8 Hood seal 4 $23.32
    8 Trunk seal 8 $46.64
    10 Scrub molding 10 $70.00
    11 Window channel (GT) 16 $83.20
    12 Radiator top seal 1 $35.91
    11 Window channel (GT/S) 10 $52.00
    15 Hood bumper 8 $54.72
    16 Vinyl edge seal/hood 12 $66.00
    16 Vinyl edge seal/engine 7 $38.50
    19 Front window surround 1 $332.00
    20L Vent window seal/left 1 $219.96
    20R Vent window seal/right 1 $219.96
    21 Type IV door seal (GTS) 26 $169.78
    22 Rear window surround 1 $345.00
    23 Upper trunk seal 4 $26.00
    24 Lower trunk seal 3 $17.49
    25 Mirror base rubber 2 $20.00
    26 Front/rear bumper rubber 14 $89.88
    27 Spyder rain gutter seal 2 $75.00
    28L Spyder roof sponge/left 1 $135.74
    28R Spyder roof sponge/right 1 $135.74
    29 Clutch pedal rubber 1 $35.00
    30 Brake pedal rubber 1 $35.00
    31 Accelerator pedal rubber 1 $23.11
    33L Qtr. window rubber/left 1 $105.96
    33R Qtr. window rubber/right 1 $105.96
    36 Exhaust shock mount 2 $12.00
    79 Bell housing boot 1 $60.00
    84A Heel pads 206 &early 246 3 $280.00
    84B Driver's side heel pad mat 1 $60.00
    84C Pass. side heel pad mat 1 $60.00
    84D Pass. side lower pad mat 1 $60.00
    85 Engine surround rubber 4.5 $38.03
    89 Euro front turn signal gasket 2 $60.00
    There are likely other sources.
    Cheers,
    Coop
  10. ENZOSON
    ENZOSON Formula Junior
    660
    Erie, Colorado
    PIETRO
    Interesting - never knew there was a seal there - my SERIES M (01296) GT does not have that ...
    Pietro
  11. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    #11 MarkT, May 30, 2011
  12. celestialcoop
    715
    Coop
    Hmmm,
    You've a good point, Mark. I'll go out in the morning and measure exact placement & take a couple of pics to compare. My bumpers are not installed, but the holes are there, for reference.
    The plot thickens.
    Coop
  13. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,330
    Iain
    Coop,
    Thank you for the detailed pic and supply source. Does the seal help to lessen the problem of exhaust fumes in the trunk?
  14. possum
    possum Formula Junior
    Sep 27, 2008
    307
    australia
    johnno
    Im pretty sure there is no seal on the boot lid.
  15. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    Only 206 GT and L-series have a seal on the boot lid.
    M- and E-series only have foam corner in the edges of the boot lid.
    Regards Matthias
  16. UroTrash
    Jan 20, 2004
    40,476
    Purgatory
    Clifford Gunboat
    Then it appears you are finished, Mark!
    Congrats!
  17. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    Thanks Matthias--
    That would explain why it is not obvious how this seal is glued on the lid so that it will contact the pinch point.
    The strange thing is that I am sure I bought the seal five years ago because I thought I had one on the trunk lid that was in tatters when I striped it down ---but it has been many years back so perhaps I bought the seal because I saw it in my old parts manual.
  18. UroTrash
    Jan 20, 2004
    40,476
    Purgatory
    Clifford Gunboat
    Even if it's not accurate, a small foam seal might be a good idea if you don't like all your clothes/belongings stinky.
  19. HMB-Dino
    HMB-Dino Formula 3
    2,281
    Pebble Beach, CA
    RonG
    #19 HMB-Dino, May 31, 2011
    As I suspected, Matthias would be able to clear this up before every M-series and E-series owner rushed out to buy up all inventory of this rubber seal.
    So this begs the question, exactly what is this "foam corner in the edges of the boot lid"? My trunk lid has no rubber/foam anywhere on it...all seals are along the edges of the trunk itself (4 pieces, one along each edge). Pictures anyone?
  20. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    #20 GermanDino, May 31, 2011
    Ron, they look like this one (self reproduction)
    They close the gap between rubber seal and trunk lid.
    Regards Matthias
  21. UroTrash
    Jan 20, 2004
    40,476
    Purgatory
    Clifford Gunboat
    Good pic, how thick is that foam?
  22. HMB-Dino
    HMB-Dino Formula 3
    2,281
    Pebble Beach, CA
    RonG
    I remember seeing that wedge shaped seal somewhere online and couldn't figure out where it would go. Problem is, now I can't recall where I saw it!
  23. UroTrash
    Jan 20, 2004
    40,476
    Purgatory
    Clifford Gunboat
    I have to say, I have a hard time seeing the point of the wedge if there is no foam across the width of the trunk lid, as it is still going to suck in exhaust.
  24. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    approx. as thick as the rubber seal
  25. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    well spotted ;-)
    it still sucks in exhaust smoke....
