Rear undertray - can it be removed while on a lift? | FerrariChat
Discussion in '360/430' started by GaryR, Nov 14, 2014.
  1. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    In looking at the parts diagrams it seems as though the rear jack support holes would require the car to be lowered off the lift onto ramps to drop the undertray, then raised back up to work on. Is that correct? I have not had her up on my lift yet so curious if I need to build some ramps..
    Thanks!
  2. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    Car needs to be jacked (there are rear jacking points) up on stands or ramps then tray removed then raised on hoist.
    Or you can raise on lift. Undo tray. lower and remove tray and raise back up.
  3. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    #3 GaryR, Nov 14, 2014
    Thanks, that's what I thought. The rear lift points go through holes in the tray from what I could see so the lift has to be pulled down/out, tray lowered, then raised back up. I'll get four ramps, unbolt tray, lower car on ramps, remove tray, lift car back up.. now to locate some nice high ramps.
    Found them - Four 12" wheel cribs should work well as a temp support... http://www.discountramps.com/wheel-cribs/p/RR-WCB/
