355 - Rear wheel offset | FerrariChat
355 Rear wheel offset
Discussion in '348/355' started by alexanderfitu, Jun 30, 2021.
  1. alexanderfitu
    alexanderfitu Rookie
    May 23, 2020
    40
    Alexander
    Hi all
    I am thinking of new wheels for my 355, due to the difficulty in getting the stock wheels refurbished. Id like to get it on the road before the end of summer, so a second set of wheels is a good idea IMO.
    Rear offset on these is a very high (low?) ET77. What is the lowest I can go on the same width wheel?
    I have found a set I like (in 19") everything fits (width, etc) but the rear offset is only available up to ET45. I fear this will move the wheel too far out, and hit the inside of the wheel arch.
    So the question is, can I move the rear wheel 3.2cm outwards without hitting anything (on a 265 rear tyre)?
    Much appreciated.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    People run 11, 15 and 25 mm spacers on 355s although the 25s are much less common. 11 seems most common.
    Sent using FerrariChat.com mobile app
  3. alexanderfitu
    May 23, 2020
    40
    Alexander
    Can anybody measure the space from the inside hub face to the outside edge on the factory wheel - I need to compare and mine is in storage :)
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #4 Ferrarium, Jul 6, 2021
    Width / 2 - offset. I think. Double check but it's just math. Start with looking up definition of offset. After that its simple. I've done it but don't recall exactly but it was easy to figure out. Good luck!
  5. alexanderfitu
    May 23, 2020
    40
    Alexander
    I did think that would be the case.
    The wheel moves out towards the bodywork 3.2cm. Additionally, the rear wheel I am fitting is a 9.5J rather than a 10J so I end up with a narrower wheel, so approximately 2.5cm. Which should be fine :)
  6. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,015
    NE FL
    Ken
    Actually, it would be a little different, and it can vary. The offset is based on the gun location in reference to the tire mounting surface, in this example, 10". 10"from inside lip to inside lip.
    There is metal outside that area, spokes can stick out as well. Typically a 10" rim is more like 11" on the outside.
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    For fender clearance spokes sticking out is not a factor but you are correct if your trying to measure for lift clearance or what not. Worth remembering, often overlooked. :thumbsup:
    For fender clearance the math is based on what ever the actual outside rim bead measurement is not what's on paper describing it.
  8. 348 TB
    348 TB Karting
    Nov 9, 2003
    120
    Mich
    Mike V
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Jenn-Air makes wheels?:)
    WATSON likes this.
  10. 348 TB
    348 TB Karting
    Nov 9, 2003
    120
    Mich
    Mike V
    it's all you see?
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    No, It was humor.:)
  12. 348 TB
    348 TB Karting
    Nov 9, 2003
    120
    Mich
    Mike V
    Good morning fellows:As of today this wheells and tire they are for sale as you all see they are in very good shape,no bend no cracks no exuses,tires are old but they onli have 150miles on them,i am willing to take tires of if buyer so decide asking price $5000.00 or make me a offer that i can refuse .
  13. 348 TB
    348 TB Karting
    Nov 9, 2003
    120
    Mich
    Mike V
    Price reduced to$ 4300.00 if anybody interested.
  14. 348 TB
    348 TB Karting
    Nov 9, 2003
    120
    Mich
    Mike V
    Price drop to $ 4,000.00 any body.
  15. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    Pm'd you.
  16. 348 TB
    348 TB Karting
    Nov 9, 2003
    120
    Mich
    Mike V
    Rims are sold.
