rear window fitment | FerrariChat
rear window fitment
Discussion in '308/328' started by swept, Feb 4, 2016.
  1. swept
    swept Rookie
    Feb 25, 2013
    35
    Washington
    Ken
    #1 swept, Feb 4, 2016
  2. 308Hutch
    308Hutch Formula Junior
    Sep 24, 2014
    369
    San Diego
    Hutch
    Bought a used OEM for our project and Jim (ivolicity) was really helpful in the process. Original exploded in fire. With a bit of sincere effort we found the best local glass guy to "pop" ours in. Mind u, not sure any current glass guys ever did a 308 rear window. And this guy was mildly freaked out:). It was about that far off and he worked it carefully... And it was bending (yes glass was really bending) to the point I almost grabbed a beer! It snapped into place vs shattering and I was certain it was gonna shatter!! Im not a glass guy but was impressed. Not a job for me but Jim or one of the other guys who has great insight should know if its close enough to "pop" in. Cool to have the glass back vs alternatives!
  3. Jdubbya
    Jdubbya The $10 Trillion Man
    43,177
    PNW
    I noticed that on mine when I first attempted to put it back in myself. Although I don't remember it being off by that much. I didn't try long and took it to a shop my local independent suggested. They got it in. Remember it's got a decent sized gasket too.
  4. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,326
    Montana
    Kim
    #4 308 milano, Feb 5, 2016
    Just finished a few months ago replacing my back glass in my 82 when I had the interior completely redone. My suggestion would be to put the rubber seal back around the glass, Secure it in place with a couple pieces of masking tape here and there then take a Carpenters string line and run at least two courses of string completely around inside the rubber channel having it exit the rubber about in the center of the glass. Take some dish soap on a rag and run the dish soap around the inside of the rubber window seal and try to install in car. Any glass shop will know this. And see what you come up with. Pretty hard to measure fit without the rubber and glass in place. I Don't think your car has been damaged it's just kind of a crazy glass to install. :) Oh, and start glass from corner and work to the other, It takes a bit of time but should fit. Be careful when you're pulling the string from the inside to set the rubber, if you pull too hard the string will tear the corners of the rubber where it seals in each corner of the car. < slow and steady >
  5. BigTex
    79,380
    Houston, Texas
    Bubba
    You have to flex the glass to pop it in....it takes gonads.
    Good luck!
    I would not hand it to someone that did not know the "rope installation" m,ethod. which is described above with string.
    That is how it is done.
  6. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,830
    Dallas Texas
    If you know you know
    ^^^^ This
    And to answer the OP question, Yes, it can be " this " off... LoL
    You should see some of the FRONT windshield gaps...
    S
  7. swept
    swept Rookie
    Feb 25, 2013
    35
    Washington
    Ken
    thanks all for the speedy and excellent responses...I will pass this info along to the glass shop and hope they get it in okay. I'll post pictures if they do:)
  8. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    Find the oldest guy in the Glass Shop, he'll know what we're talking about and how it's done! LOL
  9. swept
    swept Rookie
    Feb 25, 2013
    35
    Washington
    Ken
    slight complication, it is an early car, 1977, and doesn't have the rubber seal...shop says it was urethaned in place with an aluminum trim strip around it.
  10. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Doesn't sound right. The front glass was done that way.
  11. greg288
    greg288 Karting
    May 28, 2007
    203
    No, that is correct.
    I have a '77 as well and it is a glue-in with aluminum trim.
  12. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    Can you post a photo please?
  13. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    Just went back and looked at your photos. There is no way that that rear glass is urethaned in place. Impossible. Needs the rubber boot. Prepared to eat crow..
    We need Rifledriver to weigh in here.
    If they say it had a trim strip around it to begin with I'm going to bet it was an inset into the rubber boot to help spread and tighten a seal that may have been used on earlier cars.
  14. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,448
    Canada
    Newman
    76 and 77 rear window is held in with butle with aluminum trim similar to the windshield trim. 78 up was a rubber gasket.
  15. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    ^^ this gentleman would know. Paul if that's the case, do you have to order a year specific rear glass? After posting I did a search and looked through 270 threads on the subject but none mentioned anything other then the rubber seal. Thanks for the clarification.
    Crow... Taste just like chicken! :)
  16. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    Part number for the glass is different for butle vs rubber gasket application so the shape may have changed.
  17. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Got the same number on Eurospares website for eu glass for either a 76 or 80 car? Also trial fitted my glass car with rubber gasket seemed ok.
  18. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    Ricambi is where I checked and it had different numbers 76 vs QV and I can't see a QV being different than a 79 for example. Regardless 77 wasn't rubber mounted.
  19. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Strange qv glass is a different number to 1980 car, poosibly a change of supplier? Early cars were Saint Gobain, not sure about later cars?
  20. swept
    swept Rookie
    Feb 25, 2013
    35
    Washington
    Ken
    thanks for the replies. I will admit that over the years I have eaten as much crow as chicken :) this window probably is the original window, and I could believe that the body variances are that much, but I will defer to experienced voices. At this point the shop is trying to track down glass that matches the frame but haven't been successful.
  21. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    Take a pic of the glass maker's symbol please.
  22. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    #22 Newman, Feb 6, 2016
  23. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    crap sorry for the sideways pic.
  24. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Sometimes the Rubber Surround Molding has a groove in it. The metal Trim fits into the groove to add tension. Does the picture look like Rubber Molding with a Metal Trim insert, or am I completely up a tree?
