Reason for unable to rev beyond... | FerrariChat
Discussion in '308/328' started by Crowndog, Aug 1, 2020.
  1. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #1 Crowndog, Aug 1, 2020
    4800 rpm. Any ideas? My first thoughts:
    Broken throttle position switch (no wot signal) I only hear one click turning the throttle through full range. I think it should have 2
    Fuel pressure regulator not working correctly
    Vacuum leak
    What do you think? Also no high speed idle at cold start.
    Any suggestions are welcome. This is a 4 valve injected 308
  2. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,619
    Pittsburgh, PA
    Matt F
    But you do have full power?
    Matt
  3. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    No. It only revs to 4800rpm but does it well up to that point.
  4. Smiles
    Nov 20, 2003
    16,619
    Pittsburgh, PA
    Matt F
    Then I don't know. Interesting.
    Matt
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I will add that almost all vacuum lines are original braided covered.
  6. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,464
    Tulsa, OK
    John McDermott
    Cat or no cat?
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Cat
  8. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,691
    Mike 996
    Did this behavior begin abruptly or has max RPM been gradually decreasing? Is the max RPM the same regardless of engine load, same 4800 RPM max whether accelerating in neutral or on the road in gear?
  9. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,464
    Tulsa, OK
    John McDermott
    Plugged cat?
    Steve Magnusson likes this.
  10. Steve Magnusson
    25,147
    No, the idle switch has an audible click, but the WOT switch is a (soundless) pair of contacts (closed by a cam) that allows over-travel:
    Have you put a timing light on it to confirm/deny you aren't losing a bank of ignition?
    Also, is the warm idle unchanged (i.e., it's still the same as it was when it would rev over 4800 RPM)?
    Saabguy likes this.
  11. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Mike it was gradually
  12. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Thank you for the clarification.
    No timing light test....yet
    Yes
  13. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    The engine in question is in a Mondial 3.2
  14. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,691
    Mike 996
    If it occurred gradually, it could very well be muffler or cat breaking down internally/clogging as was suggested earlier. I've worked on cars with mufflers or cats so badly clogged that the engine could only idle - no power available above that.
  15. AUDIO RESEARCH
    AUDIO RESEARCH Formula Junior
    Feb 11, 2009
    355
    PHILIPPINES
    LUIGI RAYMUND LIRA
    What happens when the engine reaches 4,800 RPM , is there some sort of a misfire , or lost of power ? This happened to my 3.2 Mondial when the new Bosch Fuel Pump I installed was from a Mercedes 280SE . Idling and power was perfect but when it reach 5000 RPM misfiring and lost of power . When I installed the proper Bosch fuel pump for the Mondial problem solved .
  16. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,541
    Cerritos, CA.
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Is this 4800 max in any gear or just in top ? Fuel filter will limit revs in top if getting dirty
  18. Albert-LP
    Albert-LP F1 Veteran
    7,784
    around Modena, Italy
    Alberto Mantovani
    I had the same problem with both my 208 turbo: it happened around 5500 rpm in one and around 5000 rpm in the other. Solved with a full service to the Bosch fuel distributor: I was told that the membrane there is inside makes a frequency resonance due to age hardening. Both happened when they were around 33-34 years old
    It was like hitting the a rev limiter
    Ciao
  19. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    No high speed idle is likely an AAV stuck closed. You can loosen it up by spraying a lubricant inside, and work the valve back and forth with a screwdriver. This would not cause the lack of revs problem.
    I would check for proper fuel pressures there.
  20. barabba
    barabba Formula Junior
    Jun 7, 2007
    683
    Ticino / Zurich
    Fuel pump ?
