Rebuild old water pump or toss it? | FerrariChat
Discussion in '348/355' started by DavidLMcAfee, Aug 17, 2016.
  1. DavidLMcAfee
    DavidLMcAfee Formula Junior
    Nov 22, 2015
    355
    East TN
    David McAfee
    Is the water pump from a 348 worth getting the rebuild kit? As far as I know, it was working fine. Pulled it as a precaution during my recent service.
    I've been cleaning out my garage lately and trying to figure out what to keep and what to throw out.
  2. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
  3. D'Fixer
    D'Fixer Rookie
    Dec 16, 2009
    26
    Brunei Darussalam
    Mohd Sahrum
    Where do you get the rebuild kit for the water pump?
    Any supplier website, appreciate if you could share
  4. DavidLMcAfee
    Nov 22, 2015
    355
    East TN
    David McAfee
    Ricambi sells one.
  5. Ricambi America
    Sponsor Owner
  6. m.stojanovic
    m.stojanovic F1 Rookie
    3,248
    Serbia - Niš
    Miroljub Stojanovic
    Yes, but the key parts are the bearing and a metal impeller. Without those, I would not consider rebuilding the old pump. Available anywhere? Hill Engineering should perhaps step in here.
  7. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,898
    Richmond
    Pete
    I wouldn't think a metal impellar would ever fail unless the bearing had failed and caused the impellar to rub on something - in which case I don't know if it would be candidate for rebuild in the first place.
  8. m.stojanovic
    3,248
    Serbia - Niš
    Miroljub Stojanovic
    But the original impeller was plastic. If metal, of course keep it.
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,593
    San Carlos, CA
    Mitchell Le
    Dick Jordan had a stash of bearings that he machines to fit the 348 when he rebuilds them. He is retired, but his son is taking over the business. Perhaps the bearing is available there.
  10. fatbillybob
    Aug 10, 2002
    29,069
    socal
    Years ago that kit was a yellow box ferrari kit. I never understood that because there was no bearing. I thought about re-engineering the bearing to accept another bearing because the factory bearing was proprietary top secret,KGB,CIA unobtainum. 26 years later we still don't know what it is. BEcause it ran the Tbelt I thought it better to just buy a new pump. But as the pumps get more costly and more rare a rebuild solution of some kind will have to be found. There are many problems with rebuilding WP's but they are solveable and DIY possible.
  11. yelcab
    Nov 29, 2001
    13,593
    San Carlos, CA
    Mitchell Le
    I cant seem to find any mention of Jordan's son new business. I remember seeing it once here.
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    That box is so old is was white before it turned yellow
  13. dwhite
    dwhite F1 Rookie
    Why can't you measure the dimensions of the bearing and try to find one. I find it hard to believe it is proprietary.
  14. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    Many more knowledgeable than us have searched high and low for a replacement of the NLA bearing that is not the Chinese one of unknown quality and the subject of much debate. I have my OEM pump pulled from my recent major that I may dissect and take a closer look into anyway, out of curiosity. If no one has by then, I'll post up any dimensions, p/ns, etc.
  15. yelcab
    Nov 29, 2001
    13,593
    San Carlos, CA
    Mitchell Le
    Ernie, where are you? Jump in !
  16. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    It's his nephew.
  17. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #17 ernie, Aug 18, 2016
  18. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    SKF, Timkin etc all have contracts with people like Ferrari and will only produce and odd sized bearing for them etc.
    I am sure this was topic was on the forum here many years ago, talked about a few times I think actually.
    The size is unique and only sold to Ferrari, although it's an SKF bearing, in an SKF bearing box...........inside a Ferrari box. Lol
    I am liking what FBB reckons! Machine out where the bearing goes if possible and fit a bearing with a slightly larger outside diameter that is readily available off the shelf from SKF.
    Wouldn't be that hard I am sure, as long as there is meat in the water pump housing body.
    Or just rebuild or buy new water pumps, meh.
  19. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Lol, that you are! :D
  20. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #20 ernie, Aug 18, 2016
    In case anyone is wondering.
    I haven't posted a DIY water pump rebuild because I haven't done it yet. The long end shaft needs to be machined to look like this pic. I don't have the machining equipment to do it, nor have I taken the time to find a shop to do it for me.
  21. fdekeu
    fdekeu Formula Junior
    631
    Belzium
    Frank
    Maybe it is possible to design a new shaft that fits with a standard bearing
    Just an idea
    I never disassembled a water pump
  22. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    No.
    This is the exact bearing Dick Jordan was using. He machined them to fit.
  23. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Ernie, when you are ready to do it, let me know and my shop will take care of it for you :)
  24. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Thanks Dave. Will do.
