Rebuilding my '87 328 GTB | Page 3 | FerrariChat
Discussion in '308/328' started by jhh925, Mar 10, 2024.
  1. MGJBLKTR
    MGJBLKTR Karting
    Apr 10, 2006
    222
    Georgia
    MGJ
    Excellent work so far. I can't wait to see the finished project!
  2. bertrand328
    bertrand328 Formula 3
    Jun 1, 2015
    1,642
    France
    Bertrand
    @jjh925
    "My current struggle is with the insulation materials around the luggage compartment."
    To my point of view, you have to take care at the insulation between the engine bay and the passager compartment. That is a problem on GTB : the heat in the cabin with the engine just behind
  3. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    Much progress ...
    Since the last post, I've dug a bunch into the motor to get it resealed. Among other items, I've now replaced all the valve stem seals; the various seals related to the cams (with some help from folks here), cam sprockets and distributors; differential output shaft seals; shift shaft seals (wow - not so difficult if the motor is out!); block-to-transmission is resealed; differential housing is resealed; timing gear bearings & shaft seals are replaced; timing gear cover gasket replaced; all the various gaskets in the "V" (cooling manifolds, oil stand, intakes, etc) have been replaced; all new Bosch injectors have been installed with new inner & outer O-tings; etc, etc, etc.
    The timing system was refreshed ... new belts & idler pulleys were installed and timing was confirmed / adjusted for each of the four cams.
    Front & rear hubs were rebuilt. The bearings in the rear were great (so not replaced) and the bearings in the front were repacked. Parking brake is now fully re-assembled & functional.
    To be continued ...
    JOEV likes this.
  4. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    All four calipers were rebuilt with fresh seals & boots. The calipers themselves were replaced in yellow zinc.
    Intake plenum was stripped & repainted.
    The "belly pan" has been stripped, cleaned, straightened, repaired, repainted & reinstalled with new gray caulk. It looks like there were a couple of times that stuff hit or scraped underneath, and there was an odd cut all the way through the aluminum right under the parking brake lever. I can't quite figure that one out ... the p-brake handle mechanism seems to sit nearly an inch above the belly pan. Regardless, the hole has been welded shut and it's all straight again.
    New QA1 coil-overs with Eibach springs have been installed. I used Verrel's "Unobtainium" mounting eyes for the front coils. A still have the original Koni units, and I'm looking into getting them refurbished just to keep this modification fully reversible, but these sure seem lighter and I love the idea of being able to adjust the ride hight. Also, like a dumb-ass, I torqued down the inner A-arm busing mounts, so those will need to be loosened & retightened after the car us under load (or more likely I'll just lift each corner one at a time with a jack and torque stuff down at that point).
    My wife and I working together managed to get the rear glass in with no drama. After all the stories I'd read about these breaking, plus Lou Trottier's video where his 308 rear glass was shattered - I was pretty stressed about this step, but in the end it went in relatively easily. The rubber seal is new from Eurospares.
    Drip rails are glued & riveted back in.
    Christian.Fr and djs308 like this.
  5. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    I also spent a few days recovering all the headliner & rear parcel shelf bits in the correct black-and-gray wool cloth. The main issue here was that the glue (the good high-solvent stuff from DAP) tended to soak through & stain the front of the material if you sprayed or brushed it onto the back. This wasn't an issue for most of the parts ... other than the headliner shell itself, all the cloth is just stretched over the part and glued only on the borders that wrap around the back. But the headliner shell is concave and "upside down" when installed, so after a lot of experimenting with other glues, I hit on the idea of sealing the backside before spraying on the contact cement. The "sealer" that worked really well was water-based PVA glue that I cut down 4-to-1 with distilled water. Worked like charm and I was able to spray the contact cement on the headliner with zero issues. And it's adhering really well.
    Also, for the headliner, I've redone everything except the visors. I have enough left-over cloth to do them, but the visors were in perfect condition, so I've left them for now.
    I've installed 1" of new ceramic wool into the passenger side of the rear bulkhead.
    That makes sense. I now have a total of 1.5 inches of new ceramic wool, plus aramid fiber at a few strategic points where there are larger holes in the bulkhead (throttle cable, lower corners, holes where the frame members go thru), so I'm hoping this will be good.
    I've now also finally gotten everything under the front cowl installed. The hangup here was that for some *$&#$!* reason I'd neglected to put the zinc-plated "T" that connects the heater return lines into my first plating batch, so I had to do a second batch and wait for all that to come back. It's in there now - packed away way in the back, and everything else there is now torqued down & adjusted. The MC is a new unit from Superformance. The reservoir is also installed (not shown here), and I'm leaving the brake hardlines off for now so I can bench-bleed the MC later.
    For the brake booster & linkage, I was greatly aided by the YT videos by "BENZINA," who I'm pretty sure is "Nuvolari" here at FC? After using the methods he described, I double checked my work by putting a dab of clay on the end of the booster rod, attaching the MC, pulling it apart, cutting the dab of clay in half & measuring the gap - basically just like checking for valve-to-piston clearance. I adjusted the booster rod to give me just under 1.0mm of play.
    Lastly, I also finally got my front windshield glued in! I'd planned on doing this myself, but having spent nearly a grand on new glass, I figured I'd just checkbook-wrench this one. These guys from a local business were great to deal with; they understood the amount of work I had into this and worked with me to get the clips & lower trim glued into place before putting the glass in. Very pleased with the results so far - though I still have to install & seal up the trim.
    Next up:
    - Install all the headliner bits, parcel shelf padding, etc., then glue in the side windows.
    - Lace in the AC lines that run through the right rocker and up behind the right fuel tank.
    - After that's done, I'll turn back to the engine compartment (re-paint gas tanks, install the heat shields & fuel lines at rear-top-front, etc), then I should be able to take the car off the dolly and think about dropping the motor back in!
    Hours spent to date: 1,412
  6. LostAussie
    LostAussie Formula Junior
    Jun 13, 2013
    733
    Piemonte
    Stuart
    Outstanding work. Really nicely done. Complimenti!
  7. bertrand328
    Jun 1, 2015
    1,642
    France
    Bertrand
    I can't say better myself. I wish I had courage to try to do the same.
    moysiuan likes this.
  8. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    Amazing work, well done! I would love to go through a 308 or 328 like this someday -- just not mine though, it's in "leave well enough alone" condition and I frequently have to restrain myself.
    If you need any fuel hose for the tank crossover pipe sleeves, fuel pump inlet, or filler neck and can't find it locally, let me know and I think I have some extra I can share. If you replace the fuel pump and/or accumulator, note they are off-the-shelf Bosch items, so no need to buy Ferrari-boxed items and pay the upcharge. Same for the fuel filter too.
    ZikZak likes this.
  9. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    Forgot to add, kudos for getting rid of the Dinitrol. While it's authentic to the car and period, it really does not age well and it accumulates dirt and grime, which makes working on the car a dirty job. Good riddance I say! We cannot import it into the USA anymore. I had some wash off the frame after a fuel leak, and worked hard to patch it up with a similar product from Fertan USA. I found myself questioning my sanity on that one.
    I had to do a little fiberglass repair work on my wheel well liners, as the screw holes were wallowed out and cracked. They are originally chopper gun glass formed in a mold. Easy to do patch jobs with fiberglass cloth and resin then you can nitpick on the black paint color like everything else you're fixing up.
  10. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    Thank you! Every time I'd researched this in the past, there's an old F-chat post about these undercoatings where the concensus seems to be "that's what's original, you *must* put it back on," but I couldn't see the logic. So hearing the opposite ("get rid of it") from at least one other person is comforting.
  11. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    Thank you for the kind words.
    On the Bosch stuff, yeah, I'd wised up to this on my previous BMW projects. Searching by the Bosch PN usually cuts the pice in half at least!
    On the fuel lines, thanks for the offer. I need to lace the long AC lines in, but after that item, the fuel tanks and fuel lines are next. I think I've gotten what I need (mostly from Superformance, but AW Italian also has a kit for the X-pipe), but I'll keep this in mind - thanks!
  12. mixedgas
    mixedgas Formula Junior
    Apr 23, 2019
    293
    Ramona, CA
    Curious your opinion about the superformance booster/master cylinder. I realize you haven't used it in operation yet but does it seem like a quality part? It looks like you were able to re-use the reservoir, and it seems you had to adjust the rod (i.e. did it arrive ready to bolt-on?). I may need to go that route because I'm just about out of patience with the person who has been rebuilding mine since November. Thank you
  13. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    800
    Omaha, NE area, US
    Steve
    Since November?!? Something is amiss. The actual time to disassemble/reassemble is probably about a day. (I've done Brit car booster rebuilds, and it takes a couple of hours). There of course will be delays waiting on parts and for any plating or powder coating, but 6 months seems about 4 months too long, to me.
    I went the Superformance route for the MC and it was a simple bolt on, once I figured out how to adjust the pushrod correctly (found a nice writeup on this forum). My car had a non standard MC and the pushrod needed about a 2mm change (shorter) to make it right. One odd thing was I needed an inordinate amount of pumping to do a proper 'bench bleed' before I could get pressure on the front circuit. Normally I find a few pumps of cycling fluid from the MC back into the reservoir does it.
    mixedgas likes this.
  14. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    Yes, the SP part seems very high quality, and at least as solid as the original part that was in my car. After fully bleeding the system, the pedal is rock hard. The total booster rod adjustment I had to make was minimal (1-2 turns IIRC), but obviously critical.
    A few thoughts on replacing the MC:
    • "Bench" bleeding (whether you actually do it on the bench or after the MC is in the car) is critical. I did mine literally on the bench, and it took a handful of pumps (and maybe 10-ish minutes of just letting it rest before pumping again) to get the bubbles out. But having done so, the actual bleeding of the system was almost trivially easy.
    • SP sells two different MCs for our cars. The difference between the two is a sizing issue. I'd encourage anyone who's going to buy from them to contact them by email to make sure you order the right one.
    • One caution: there's a rubber bumper under the rod that you need to adjust. It's located down inside the brake booster under the end of the rod. That bumper is just a slip fit in there. If it rotates out of place while you're reassembling things, it will mess up your fitment. AMHIK.
  15. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    Very happy with recent progress.
    I tried to figure out how to get all-new material for the rear bulkhead covering, but I finally gave up. Instead, I wire-brushed all the old foam off and glued new 1/2 inch foam onto the back of the main pad. I used the same 1/2 inch foam on the small pieces that go under the rear window and up along the inside of the C-pillars, then ground that foam down to about 1/4 inch.
    Headliner and rear parcel shelf pieces are all installed. First pic is a test fit before the windows went in ... I figured it would be way easier & cleaner to put the rear side windows in without that parcel shelf in place. I'm really happy with how this work turned out.
    Rear windows went in next (thanks for the help!):
    Next I refurbished the gas tanks. The silver reflective paint was pretty worn out and some of the coating had to be redone:
    New felt pads for the tanks. I used 1/2 inch felt and cut the pieces with new utility blades.
    Before installing the re-painted tanks I took a few pics of the insides of the tanks just to check the conditions. I was pleasantly surprised how clean they are!
    Gas tanks are now installed and most of the various vent & fill hoses (all new) are also installed:
    Next, I'm hoping to turn back to the motor for a valve adjust and final check before dropping it back in.
    Total hours to-date: 1,482.
    ZikZak, moysiuan, ChevyDave and 2 others like this.
  16. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    Well, as usual, plenty of family stuff planned this summer (a couple of graduations, and couple of kids' moves, a couple of weekend getaways), and so not as much getting done on the 328 project as I'd been hoping. My goal was (is?) to get the car back on the road before mid-April 2026, but right now that's feeling very optimistic.
    What I should have been doing this summer while the weather is still warm is getting the rest of the body painted - doors, hood, engine cover, etc. Instead, I've been getting engine & drive-train put back together.
    Cam belts changed, valves adjusted, cams timed with dial indicators on the #1 piston, the #1 intake & exhaust valves, and again same at #8. Measuring cam belt tension was awkward, but I was getting a consistent readings for max tensioner deflection, so I feel pretty good about belt tension.
    I tried to get as much of the engine reassembled as possible before putting it back in.
    And dropped it back in ...
    Half-shafts were fully rebuilt and the shafts themselves repainted:
    Exhaust system is back in place. I think I posted a picture of the cat as it came on the car - the honeycomb itself was breaking up:
    For now, I've decided to "de-can" the cat (I think that's the term). I'll keep looking for an OEM replacement, or more likely getting it re-cored by Fabspeed at some point.
    Both fiberglass intake ducts were refurbished ... fiberglass repaired and sanded, assembly repainted, metal brackets painted of repeated and riveted back on. And of course, I totally forgot to take progress pics, so just one "after" pic:
    And I made some progress trying to find good replacement zip-ties. I found a good (but not perfect) replacements for the wide, white zip-ties and the wide, black "Colson LeGrande" zip-ties (old on top, new on bottom):
    I did manage to get at least a little progress done on the remaining paint & body. Getting a little help on the engine cover. Here, we're working on the typical dings on the rear edge where I think people tend to try to slam the cover closed by pressing in the middle (instead of at the sides where the latches are):
    Also, great progress on getting the fuel lines back in. Verell's "Unobtainium" tool to press new fuel lines onto the various barbed fittings has been working like a charm:
    One challenge here will be to fine the right zip-ties to bundle the lines. The white zip ties in the pics above are the wrong ones and are hopefully just temporary till I find something closer to the original; I put them there to confirm that the new plastic lines are the right lengths. As for the clip-in brackets that attach to the hard lines, I'll be using the Superformance reproduction white clips.
    And just for fun, here's a before and after from inside the left-rear wheel well:
    Total hours to date: 1,660
  17. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    Well, as usual, plenty of family stuff panned this summer (a couple of graduations, and couple of kids' moves, a couple of weekend getaways), and not as much getting done on the 328 project as I'd been hoping. My goal was to (is?) to get the car back on the road before mid-April 2026, but right now that's feeling very optimistic.
    For now, I've decided to "de-can" the cat (I think that's the term). I'll keep looking for an OEM replacement, or more likely getting it re-cored by Fabspeed.
  18. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    Continued ...
    One challenge here will be to fine the right zip-ties to bundle the lines. The white zip ties are the wrong ones and are hopefully just temporary till I find something closer to the original. I put them there to confirm that the new plastic lines are the right lengths. As for the clip-in brackets that attach to the hard lines, I'll be using the Superformance reproduction white clips.
    bertrand328 and rwbolt1 like this.
  19. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    That looks fantastic, so clean and nice compared to my aged/original engine bay.
    If you haven't already, do a test fit of the rear driver's side wheel well liner to make sure your coolant hose routing is OK. It is a little fussy in my experience, and if there is any interference, the liner can press the hose into contact with brackets and fasteners that can cause wear. The hose had been routed incorrectly on my 328 by some previous mechanic, and I had to get creative to remedy it and prevent further wear to the hose. In the future I will need to disconnect the hose from the engine to get the routing correct, but will wait until I have a real reason to drain the cooling system.
    The other thing that had been botched, and is very sensitive to pressure from the wheel well liner, is the multi-pin engine harness connector attached to the oil cooler inlet duct. I had to go nuts with zip ties to make sure that connection stays secure on my car and that there is no pressure on it from the wheel well liner.
    It's nice to have access to so many things from that driver's side wheel well, but Ferrari sure crammed a lot of sensitive hoses and connectors in that area.
  20. jhh925
    jhh925 Karting
    79
    Reno
    Jens
    Quick update. I've given up on doing the rest of the painting myself. The process itself isn't intimidating, it's just that I'm finding my self very very short on time. Between house projects and another old BMW project that I took on (should have taken just a few hours, and yet here we are ...), I'm feeling like I need to get a bit of help.
    So, I've done the initial prep on the remaining body panels (doors & door handles, hood, engine cover, headlight parts, bumper covers), and I've taken them to a shop down in the Bay Area I've used many times before. I should have the painted parts back sometime in January and stay on track for an April "completion."
    With the remaining body work offloaded, I've started in on the electrical system. The goal now is to get all the wiring in so I can start testing the electrical system and get to a "first start" attempt before all the interior parts are in that would make it harder to diagnose & fix problems later.
    Here's the installed dash:
    "Hey, that looks like a really weird fuse panel - what's up with that?" That's a testing prototype for a new replacement fuse panel. On most of my recent BMW projects, I've used replacement blade-style fuse panels from Holy Grail Labs. Their stuff is really good, and the plan here is to use modern multi-layer PCBs, then install that in a new plastic housing. So the HGL part will fully replace the original fuse panel (excluding the metal cover on the back), with all relays, fuses & connectors going in the same spots as the original.
    On the dash installation, I'm not sure I've gotten the leading edge of the dash (where it tucks in under the windshield) installed correctly. As you see the dash above, the mounting holes & screws in the door jambs line up perfectly, and the underside of the dash where it mounts to one of the metal brackets on the frame also lines up perfectly. But in this position, there's a decent gap between the top side of the frame where the air is fed into the round center vents, and the underside of the dash. That seems wrong to me. And here's my question:
    • There's a black metal trim piece under the bottom leading edge of the windshield that was riveted to the frame before the windshield was installed. This picture isn't great, but here you can see that the leading edge of the dash sits ON TOP OF that trim piece. Is the dash supposed to tuck in UNDER that trim piece? In trying to fit the dash in, I'm not sure it even would have been possible to do so.
    • And if the dash does not slip under that trim piece, is there some kind of mounting mechanism that's intended to hold the dash down? Or do I just need to use thicker foam sealing strips to seal the dash to the dash vents?
    Total hours to date: 1,733 hours
