Rebuilding / service time for 308 engine | FerrariChat
Discussion in '308/328' started by Curriculum, May 9, 2024.
  1. Curriculum
    Curriculum Rookie
    May 9, 2024
    31
    Curriculum
    Hi.
    I am very surprised about the service costs of an engine rebuilding / servicing.
    (I have a dino 308gt4 from 1974 carburator).
    The prices variy from 5.000 to 20.000 euro in Europe.
    Here my own calculation example:
    Total price divided by hourly labour rate = required time
    20.000euro à 100euro/h = 200h = 25 days !
    5.000euro à 100euro/h = 50h = 6 days
    I can't believe that a skilled mechanic needs so many hours.
    Does anyone has any experience?
    *Of course the engine has to be in a good overall condition. No major parts to change.
    Br
    Felix
  2. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    Is a vague term that could include or exclude a lot of things depending on who you ask.
  3. Curriculum
    Curriculum Rookie
    May 9, 2024
    31
    Curriculum
    What do you mean?
  4. Rifledriver
    37,121
    Well if there are no major parts to change I guess it doesn't need rebuilding does it?
    The job is always easy for the guy who doesn't have to do it.
  5. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    Couldn't be a more true statement.
  6. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    There is a surprising amount of time spent in just cleaning, inspecting and measuring parts vs factory specs in order to determine what needs to be replaced or reconditioned.
  7. Curriculum
    Curriculum Rookie
    May 9, 2024
    31
    Curriculum
    I still can't believe that the work takes weeks. What do they others say? Who rebuilt his engine in the past? Who did it already several times?
  8. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    I have about 300 miles on my rebuilt 308GT4 engine. The heads were off the engine when I bought the car. I had no one local who would even attempt a rebuild and others I contacted were not real enthusiastic about taking it on as it appeared the internals were no longer stock but I had no documentation as to what was done.
    I found a local engine builder who agreed to help me. I stripped the engine, cleaned and measured all the parts for tolerance. I went through every TAV page to get the part numbers of what I needed to replace, did all the ordering and checked what I received. I cataloged all the external fasteners and ordered replacements in yellow zink finish.
    I took all the parts to the engine builder along with my conversions of all dimensions into English units as he didn’t like working in metric.
    I worked with him side by side on the rebuild with him doing all the hard stuff and me being the gofer. That is my only experience with a 308 rebuild.
    How many days do you think it should take to rebuild your engine?
  9. Rifledriver
    37,121
    Many times over the last 45 years in the Ferrari business.
    You have zero idea what you are talking about. None. Clueless.
    School is not out yet. Get back to class and leave the adults alone.
    Hans Castorp and radlu like this.
  10. Curriculum
    Curriculum Rookie
    May 9, 2024
    31
    Curriculum
    #10 Curriculum, May 10, 2024
    Then you are the definetely RIGHT guy to ask:
    In your 45 years in the Ferrari business you are defintely able to give me an AVERAGE number of hours for engines in average condition.
    Have you been working as a mechanic?
    For a costumer quote, a dealer should know in advance how long he will spend - even roughly.
  11. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    Might be better off giving details of your car as “average” is a relative term. Current mileage, history of prior engine work, what issues you see that suggest it needs a rebuild and pictures of engine and general car condition would give some data points of your car, its past life and you as an owner.
    We have to be realistic that as someone who has gravitated to Ferrari ownership we are generally not people that are happy with “close enough is good enough” and anyone doing the work has to factor in that they take the time to do it right first time or they will erode all their profit on the job by fixing every minor oil weep and carb stumble that you find once you get it home.
    Most 3*8 owners would not be satisfied that a new set of rings, fresh head gaskets and a wipe down with an gasoline soaked rag constitutes a rebuild.
  12. Rifledriver
    37,121
    Your questions reflect your lack of knowledge and experience in the matter but yet instead of asking questions your opening salvo is to question the veracity of the information. What possible good will it do to debate you? You already know it all.
    I never give estimates on that nature of job until it is in my shop and I have spent considerable time researching its condition. Then and only then do I tell you whatever number I give you may get lit on fire the first day. Have you ever experienced heads stuck on from corrosion? Not a single way to tell in advance and I have seen Ferrari engines that took over a week of man hours just to remove a head. I had one recently a couple of the liners needed to be machined out and taken out in little pieces. I had another with head studs so stuck in the block from corrosion it went 2000+ miles in shipping before one of the several machine shops succeeded in getting the last 3 head studs out.
    You know nothing but profess the contrary.
    Go away.
  13. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,875
    Mike 996
    YEP, that's the key - How much actual WORK is necessary. That's totally unknown until the work is actually done. Re removing heads: it took me a couple of days to get the head off of an E-Jag 3.8 motor due to corrosion. A non-problem example took maybe 15 minutes to pull the head! You can't charge the same amount for both situations even though, by the book, they are the "same" operation.
  14. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    Lets start with your opening statement. Rebuilding and servicing are 2 completely different things. When it comes to major engine work on any Ferrari 5000 isn't getting you far. If we are genuinely talking about rebuilding work that means you are pulling the engine. I doubt you're getting an engine pulled for 5000 let alone work completed. So again.. qualify "what" you are getting completed for those quoted rates? That low end could simply be a lock and swap timing belt and an Italian tune up.... maybe.
    Your question is too vague and doesn't have supporting details.
    Experienced shops know that working on these takes time and until "you are in there" there is no way to know. Shop time is real and inefficiencies' are HUGE. You don't run down to the neighborhood parts store when you stumble on needing something that was unplanned.. You're days away via mail order AT BEST. From a shop perspective that means tabling the work and moving onto something else till next week.
  15. Rifledriver
    37,121
    You are just feeding the troll.
    MFlanagan likes this.
  16. Curriculum
    Curriculum Rookie
    May 9, 2024
    31
    Curriculum
    hi. I am not only owner of a 308 but have been owner of vintage cars and of course daily cars for years.
    During all these years, mechanics always could give me a price estimation before they start to repair my cars (mechanical work, body, interieur, electronic...). And I was never surprised with costs far from the offer they made before.
    I do not need an exat sum, but I am sure that especially people with 45 year of experience have in mind how long they worked in AVERAGE on a 308 engine. I am not interested in the fastest ever rebuild engine and not in the slowest rebuild engine. Just a rough number of hours.
    Her some work which could be necessary (112.000km):
    Remove the engine, new valves, new piston rings, reseal everything (new gaskets) (the engine is leaking a bit), and a general check of the rest of the engine. Engine re-installation.
  17. Rifledriver
    37,121
    I do give real clients a rough estimate and stress it is a best case and it will most likely go up and keep them informed and then only after inspecting the car. I never give estimates on the internet and I never accept work on cars whose owner starts a conversation the way you did. The good shops have far too much business to go through that.
    I learned a longtime ago that if I go through life telling shoe makers how to make shoes I'll never get good shoes made.
    Hans Castorp and Newman like this.
  18. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    867
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    With the head separation and known galvanic problems it’s fair to say that an experienced shop would layer up several jobs simultaneously. So every morning ( assuming it’s not playing ball ) be able to within 10 mins reapply penetration fluid and apply more force with the jig .The jig they have had made and used many yrs and carry in the shop specifically to do this job .
    So I don’t buy into the how longs a piece of string argument.
    I have got sympathy for the OP .
    Obviously what the shop owner can’t say the exact date it’s gonna be finished due to the variable time the head’s seperate, and parts availability.
    But if a parts gonna take 3 weeks to arrive the shop guy can’t bill the punter 3 weeks for sitting around and waiting as I said he will layer in other ( bread + butter ? ) jobs to keep his “ timesheet “ occupied. The same as starring at the head removal jig after he’s adjusted it .
    He should be able to give a staged quote depending how deep it ends up .
    I can’t see the issue of giving a ball park 1 inc rings , shells , gaskets every oil seal , belts , sending ancillaries off for refurbs and other s ball park 2 + 3 inc valve springs , liners, piston sets etc .
    Set off on one journey and via email / pics give periodic up a dates if anything else appears eg “ oil pump gears look knackered …for an extra ( insert $ ) we can replace “ while we are in “ Or the €150 starter motor refurbs not ideal instead we need a new one @ what ever $$ .
