Rebuilt steering rack - now it's really stiff... | Page 2 | FerrariChat
Discussion in '308/328' started by Andy 308GTB, May 16, 2016.
  1. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Yes they certainly do. A quick Google search brings up around 10 rack rebuilders on the first few pages. Maybe not many Marina (but probably some!) but mostly Jaguar, Lotus, TVR, Jensen, Mini, Triumph, MG, Aston Martin etc etc.
    Its just one of the countless specialist classic car and motorsport related services which employ thousands of people in the UK in small workshops all over the country.
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
  3. pshoejberg
    pshoejberg Formula 3
    1,864
    Denmark
    Peter H
    I have rebuild 3 of these racks with never having to change the original shims. The trick is, as Martin states, to ensure enough play in the bushing for correct turning resistance. The tolerance can be adjusted with a simple reamer or with fine grinding paper wrapped on a stick.
    Best regards Peter
  4. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Fwiw I used a small brake cylinder hone.
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Peter, were all three rebuilds done on the same rack or different ones? If different do you know the longest mileage obtained? If the same then what was the average interval? I'm assuming you went with metal as opposed to plastic bushings.
  6. pshoejberg
    1,864
    Denmark
    Peter H
    Rebuild my 308 rack twice; First time using a plastic bushing that disintegrated less than a year later (Most likely crispy NOS bushing), then installed a bronze bushing that's still running strong. Rebuild my 246 rack using home made bronze bushing as well. Both racks had run +- 50K miles prior rebuild. I bet that these racks can live forever if they are rebuild with a bronze or Delron bushing, filled with the right type of grease and the rubber belly's are kept intact.
    Regards Peter
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Great info, thanks.
  8. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    Just out of curiosity, is the steering rack the same for LHD & RHD? I just put my LHD one back in, and it seems it would work either way.
  9. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Isn't the pinion on the left on a LHD?
  10. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,286
    Gold Coast, Aust.
    Patrick
    No
  11. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,294
    Black Forest Germany
    Martin N.
    Design is mirrored, what does not mean, that you can simply flip it over.
    Best
    Martin
