Recomendations for 308 upgrades, fixes or changes? | FerrariChat
Discussion in '308/328' started by Jonny Law, Feb 27, 2010.
  1. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    Recently got my first Fcar which is a 308 GTBi '81 with 45k on it. My first inclination is to hit the basic stuff such as fluids, filters, spark plugs and wires, cap and rotor, as well as replacing worn or tired hoses.
    But I am wondering about the after market items. I hear a lot about replacing the OEM fuse block with a Bridman. Unless you ask a Ftech or Fservice manager and then they tell not to worry about it until it becomes a problem. I like to be a little more proactive. It was also recommended to add relays to some of the major items such as power windows and head lights. I like the cover plates for the timing belts. Good News For 308 Owners http://www.ferrarichat.com/forum/showthread.php?t=275017
    Any other recommendations or ideas?
  2. MBFerrari
    MBFerrari F1 Veteran
    Jul 2, 2008
    6,057
    NoVA
    Matt B
  3. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    It depends on alot of things, do you want to keep it all original?
  4. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    Thanks Matt
    Not necessarily. Its not 100% original as it is, and would rather make improvements then risk major damage due to a design flaw.
  5. Dino246gt
    Dino246gt Formula 3
    Mar 26, 2007
    1,038
    Winnipeg, Manitoba,
    Dennis Ezmerlian
    Get Birdman's fuse blocks first thing, that's what I did, and EVERYTHING works better. I also got the window accelerators. If you have the money, change all hoses, belts and anything that would be deteriorated with time over mileage, that's rubber and easily accessible gaskets. It's not that difficult and the driving experience will be more pleasureable while still listening for anything going wrong. All fluids is a given and get the proper oil filter, UFI. I've driven mine for 4 years with NO problems, although I do a lot or preventative maintenence mostly because I like to. These cars are meant to be driven and with proper maintenence are bulletproof. Mine's also a 2v 308GTBi congratulations on your new baby.
  6. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    Get towing insurance and drive it. Enjoy the ride.
  7. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    Congrats and welcome to the club!!!
    PDG
  8. TURBOQV
    TURBOQV Formula Junior
    Mar 6, 2003
    838
    NV and Utah
    Get Boost! You will like it! Viagra for your Ferrari.
    Congrats on the car.
    Cheers
  9. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    #9 AZDoug, Feb 28, 2010
    It WILL become a problem when you don't really want it to be. Replace them.
    Other than that, I saw a nice picture on here several months ago with a 360 motor installed in someones 308. That looks like a nice upgrade. :)
    Doug
    Factory 308 fuseblock and roadside repair from 20 years ago:
    I can't for the life on me figure out why the frickin' idiots used a thermoplastic as a fuseblock substrate.
  10. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    Does the Birdman use glass fuses or the plastic push-in type?
  11. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Push-In blade type automotive fuses are called ATO/ATC. The Birdman Block uses AGC glass or ceramic fuses, the standard cylindrical fuses for 50 years in the US. A new fuseblock is a MUST HAVE as the old fuse block doesn't go out suddenly, it goes out gradually, and half the cars issues will be electrical.
    Also replace all relays in the panel.
    Concerns with headlight brightness and window speed will keep you busy AFTER the car is road worthy and reliable.
    BUT FIRST - BEFORE ANYTHING ELSE - learn how to use the SEARCH function here including the Advanced Search. It's tricky. awkward, slow and lacks features but is necessary.
    _________________________
    http://www.FerrariWiring.com
