Recommend me a wireless rooter | FerrariChat
Discussion in 'Technology' started by Etcetera, Jun 12, 2009.
  1. Etcetera
    Etcetera Two Time F1 World Champ
    23,992
    C6H14O5
    Anyone recommend a wireless [algore]rooter[/algore] for me?
  2. thecarreaper
    thecarreaper F1 World Champ
    18,071
    Savannah
    i am using a Wireless-G WPA2 encrypted router on my home network its a 2.4 gig HZ with password protection. been happy with it.
  3. Etcetera
    23,992
    C6H14O5
    How happy, exactly?
    Tell me about your mother.
  4. sm1810
    sm1810 Karting
    May 21, 2009
    96
    Dallas, TX
    any linksys router (WRT54GL is the most famous one they have), OR to make it exponentially easier to set-up I'd use an Apple TimeCapsule with buit-in hard drive (works very well with Macs/Macbooks/etc.)
    good luck..
  5. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,274
    Seattle Area
    Dave
    Call Roto Rooter and wash your cares right down the drain :)
    Seriously, always been a Linksys fan - WRT54G is my standard... works
    as it should, very reliable, and not very expensive.
    Jedi
  6. EnzymaticRacer
    EnzymaticRacer F1 Veteran
    Feb 27, 2005
    5,367
    Do you just need wireless b/g capability, or do you have any devices that use Wireless-N? Most new laptops have cards capable of the N, which is significantly faster. Most devices will start to move towards N once they finalize the standard.
    As for G routers... Linksys WRT54g/s routers with are generally considered the standard.
    We personally have a Linksys WRT160n router, which has N capability. We have had it for a couple of months and it has been rock solid so far.
    If you want dual-band capability, I hear the WRT610 is a good choice for that. The idea behind that is that you have two wireless networks running in tandem... one at 2.4ghz for the b/g spectrum, another at 5ghz for the N devices... this will improve reliability of both networks as it cuts down on interference.
  7. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    Who is your Internet service provider? I ask because the Linksys is a great router but if you are on Verizon DSL you will need to change the MTU to 1492 to get the best throughput. Verizon's DSL is based upon LANe and can not handle a typical Ethernet frame with a MTU of 1500 without breaking it down to 1492. This means your DSL modem get congested. By setting your routers MTU to 1492 you will have a consistant frame rate from computer to the Verizon Internet entry point without contention.
  8. taber
    taber Formula 3
    Mar 4, 2005
    1,582
    San Francisco
    Norman
    Linksys WRT54G/GS/GL
    I have the WRT54GL with a 3rd party firmware installed. Cool way to setup the router (I just track bandwidth usage/traffic) and offers tools you normally see in much more expensive routers!
  9. Pepsi10
    Pepsi10 Formula Junior
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Try the Apple Airport Extreme. It is more expensive but it works great. Just installed another one at my mother in laws. Worked great.
  10. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    If you have an iPhone, you can use it as a modem/rooter.
    Not sure if that's true. I read that on a couple forums.
  11. Waldoonay
    Waldoonay Formula Junior
    Mar 5, 2007
    630
    Ottawa/Abu Dhabi
    Walid Z
    WRT160N is great and is backwards compatible with G and B. Range is amazing!
  12. djui5
    djui5 F1 Veteran
    Aug 9, 2006
    5,418
    Phoenix, Arizona
    Netgear N :D I get up to 16Mb/s wireless
  13. CAS
    CAS F1 Rookie
    Nov 6, 2003
    2,683
    San Diego, CA
    Clint
    WRT54G!!!
  14. nopassn
    nopassn Formula 3
    Nov 19, 2003
    1,959
    Kansas City
    Roy
    I recently upgraded from my WRT54G to the WRT610N - same easy interface as the 54G, same stability, dual-band wireless N... banging fast with my MacBook Pro. If you don't need the N spec, The WRT54G/GS/etc... is a great little router.
  15. REMIX
    REMIX Two Time F1 World Champ
    #15 REMIX, Jun 22, 2009
  16. Etcetera
    23,992
    C6H14O5
    Why are you wearing a cheerleader's costume?
  17. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    There are only really two reasons why you should spend the money on 11n equipment today:
    - You need extra range. You have a large, multistory house and a normal (11g) router won't cover the entire area
    - You need device to device speed. 11g's max throughput is 20 Mbps so unless your Internet connection is faster than that (FIOS) then you don't need the extra speed. However, if you are running a media server wireless in your home, 11n is a good purchase.
    GT
  18. CrusaderTBC
    CrusaderTBC Karting
    Apr 28, 2009
    157
    Washington, DC
    Tony
    I use a 3Com Officeconnect Wireless a/b/g wireless router. It's a solid performer.
