Recommendations on PBX systems? | FerrariChat
Discussion in 'Other Off Topic Forum' started by bobafett, Dec 6, 2005.
  1. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Need to find a decent PBX system for home use. 5 lines, at least 12 extensions, predominantly cordless.
    Nothing fancy, I don't want any silly features or gimmicks. I looked into it 3-4 years ago and couldn't find a system that worked well for lots of cordless use.
    Any recommendations on individual systems, brands, pricing guidelines, etc. are much appreciated. I do not want some OTT office system.
    Thanks!
    --Dan
  2. PeterS
    PeterS Five Time F1 World Champ
    52,224
    Goodyear, AZ
    PeterS
    With a need for 5 lines and 12 extensions, you probably won't have time for any karting :)
  3. modoindustries
    modoindustries Formula Junior
    316
    Bel Air, CA
    Sami C.
  4. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    five lines is the killer.
    panasonic makes a system designed for homes, but damn if i can remember the model information. no clue if it supports five lines.
    why not set up an asterisk server? source 5 DIDs and route them in the server to w/l VoIP phones? http://www.voipsuppy.com/
    doody.
  5. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Dude-man: i know most systems say hey, 4 lines is the tops. I suppose I could get away with 4 as one is a dedicated fax, but it'd be nice to route everything through the PBX.
    --Dan
  6. Moku
    Moku Karting
    Dec 17, 2004
    107
    Santa Rosa, CA
    Rob & Jody
    Sure thing.
    Panasonic KX-TAW848 for the KSU. Will handle your needs without issue. Max 8 lines and 28 wireless multi-cell phones.
    KX-TVA50 or 200 for Voice mail. These are *much* nicer than the earlier TVS series which have now been discontinued for the most part.
    KX-TD7690 or 7680 for the wireless phones. Not cheap but extremely rugged.
    KX-T0141 cell stations. Up to 4 can be set up to minimize / eliminate the chance of drop out.
    One wired unit for system programming. KX-T7736. The majority of your programming will be done from a PC but you'll need at least one wired unit any way you go.
    There's a lot more to this but the end result will be a solid system that you can depend on day in / day out. Easy to maintain without the need for outside consulting, etc.
    PM me if you want more info. I can direct you to worthy vendors and can probably make your decision making process a bit easier... :)
    Rob
  7. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Rob - I'll definetly drop you a note for more info. Thanks very much.
    --Dan
  8. Shark49
    Shark49 Formula Junior
    Mar 31, 2005
    773
    Boone, NC
    Nathan
    Nortel makes a great system, we use it all the time down here for our jobsite trailers.
    -Nate
