Recommended cold tire pressure | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by Shoffman, Jun 27, 2015.
  1. Shoffman
    Shoffman Karting
    Mar 26, 2015
    109
    Quick question for the group on 2015 Cali T. Here in the States, on the 20"rims, the manual indicates that tire pressure should 35psi in the front and 32psi in the rear (these are the 245 and 285/35 ZR 20s), the side of the door panel indicates that these tires should be only 32psi in the front and 29psi in the rear and my dealer told me that all the tires should be between 35-40 psi. What do you guys recommend? Thoughts?
  2. Royalpar1
    Royalpar1 Formula 3
    Oct 18, 2013
    1,767
    South Florida
    Mitchell Lombard
    Personally, I have always used on my Maserati and this Ferrari 32 front /34 rear
  3. Shoffman
    Shoffman Karting
    Mar 26, 2015
    109
    Thx; called service dept and technican told me he always uses 32psi all around. I guess everyone has there own views.
  4. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Start with 35/32. The manual is usually more up to date than the sticker on the door, and it's possible that they put the wrong sticker on the car (for the standard rims/tires, maybe?). If ultra-low profile tires on large rims have too little air, they can too easily fall prey to potholes. From there, adjust to suit desired handling.
  5. Shoffman
    Shoffman Karting
    Mar 26, 2015
    109
    Handling better with firmer or softer tires?
  6. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    In-between. The factory has it about right. Run less air at the track to keep them from getting way overinflated but put them back to stock afterwards. Take out a bit from the front compared to rear or put more in rear compared to front and you can feel differences in understeer and oversteer.
