Recommended tire size for 430 rims on a 360 | FerrariChat
Discussion in '360/430' started by SeaNile, Apr 6, 2010.
  1. SeaNile
    SeaNile Formula Junior
    Jan 25, 2010
    679
    West Chester, PA
    Trying to get the last pieces of a deal together so I can get the 430 rims on my 360. Is there a recommened tire size for these rims when on a 360? Haven't started shopping for tires yet but will do so today after I figure out what size to go with on my new to me 430 rims.
  2. away
    away Formula Junior
    Aug 5, 2004
    635
    Lansdale, PA
    Andrew
    225/35/19 Front
    285/35/19 Rear
    Hope you're able to work it out John.
  3. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    will that change the handling?
  4. tazandjan
    39,191
    Ray- Those are the same size tires fitted to the 360 CS, and f430 wheels are exactly the same size as the CS wheels at 7.5Jx19" F and 10Jx19" R with identical offsets. Ferrari chose those tire sizes because they are very nearly the same diameter as the 18" wheels fitted to normal 360s. What you end up with is a stiffer wheel tire combination with slightly increased tread width. In general, handling and braking should be slightly improved and ride quality will be slightly degraded.
    Here is a list of all the wheel combinations I have found for late model Ferraris, missing a few of the newest model optional wheels.
    Taz
    Terry Phillips
    Ferrari OEM Wheel Sizes
    5 X 114 mm Bolt Pattern
    612
    Five Spoke F 18”, R 19”, 5 X 114 mm
    Front 8J X 18 ET 43.5 mm , R 10J X 19 ET 51.1 mm
    Five Spoke Modulars 19”, 5 X 114 mm
    Front 8J X 19 ET 43.5 mm, Rear 10J X 19 ET 51.1 mm
    Challenge Monolithic 20”, 5 X 114 mm
    Front 8J X 20 ET 43.5 mm, Rear 10J X 20 ET 51.1 mm
    599/HGTE
    Five Spoke F 19”, R 20”, 5 X 114 mm
    Front 8J X 19 ET 43.5 mm, Rear 11J X 20 ET 63.8 mm
    Front 8J X 20 ET 43.5 mm, Rear 11J X 20 ET 63.8 mm
    HGTE Five Spoke 20”, 5 X 114 mm
    Front 8.5J X 20 ET 40 mm, Rear 11J X 20 ET 63.8 mm
    California
    Pentagram Forged 19”, 5 X 114 mm
    Front 8J X 19 ET 44 mm, Rear 10J X 19 ET 52.5 mm
    458
    Front 8.5J X 20 ET 46.5mm, Rear 10.5J X 20 ET 58.5 mm
    5 X 108 mm Bolt Pattern
    348
    Five Spoke 17” Early, 5 X 108 mm
    Front 7.5J X 17 ET 49 mm, Rear 9J X 17 ET 68 mm
    Five Spoke 17” Late, 5 X 108 mm
    Front 7.5J X 17 ET 49 mm, Rear 9J X 17 ET 43.05 mm
    355
    Five Spoke 18”, 5 X 108 mm
    Front 7.5J X 18 ET 32 mm, Rear 10J X 18 ET 77.9 mm
    456 GT/456M
    Five Spoke 17”, 5 X 108 mm
    Front 8.5J X 17 ET 50 mm, Rear 10J X 17 ET 24.6mm
    360
    Five Spoke and Modular 18”, 5 X 108 mm
    Front 7.5J X 18 ET 31.5 mm, Rear 10J X 18 ET 39 mm
    360 Challenge Stradale
    Challenge Monolithic 19”, 5 X 108 mm
    Front 7.5J X 19 ET 31.5 mm, Rear 10J X 19 ET 39 mm
    550/575M/575 Superamerica
    550/575M Five Spoke/Modular 18”, 5 X 108 mm
    Front 8.5J X 18 ET 43.65 mm, Rear 10.5J X 18 ET 32 mm
    575M/575 Superamerica Five Spoke Modular, 5 X 108 mm
    Front 8.5J X 19 ET 43.65 mm, Rear 10.5J X 19 ET 32 mm
    f430
    Five (Ten) Spoke and Challenge Monolithic 19”, 5 X 108 mm
    Scuderia/16M
    10 Spoke, Five Spoke 19”, 5 X 108 mm
    Front 8J X 19 ET 31.5 mm, Rear 10J X 19 ET 39 mm
  5. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,459
    will a set of 295-30-19 fit on a 430 wheel for a 360 for the rears?
