Recored radiator now leaking again | FerrariChat
Discussion in '206/246' started by MarkT, Jul 5, 2024.
  1. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    One of the first things I did when I started to restore my 246 back in 1997 was to pull my radiator and have a new core soldered in. The OEM core was in bad shape and the radiator shop recommended a new core which worked very well these last 27 years---about the same length of time as the OEM.
    Last month it began to leak along the right side tank so I have to pull it out and either install a new core or buy a new radiator.
    Years back Jon recommended having Ron Davis Racing fabricate a new aluminum radiator because they have the correct pattern.
    Jon, do you still use and recommend the Ron Davis radiator or have you moved on to another fabricator for your restorations?
  2. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,304
    Sergio Tavares
  3. fatbillybob
    Aug 10, 2002
    28,965
    socal
    Ron Davis is the best. We race on those radiators and they never fail.
  4. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    Sergiio- I saw that on eBay along with many like it at the same low price. Almost too good to be true at that price which makes me worried that you get what you pay for.
    For the price, it may be worth a try if it actually fits. It looks like it has the bung hole for the fan thermo switch but I could not see clearly if it had a plug in it or if you had to drill and tap it for the switch.
  5. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    With your and Jon's strong recommendation, I believe that having Ron fabricate one for me will be the way I will go.
    The aluminum ones offered on eBay are 10x less money, but if they do not fit, have porous welds, or are fabricated with thin aluminum, I would be throwing money into a hole.
    They seem to have flooded eBay which is strange since the market does not seem large enough to have a Chinese factory churn them out.
    Has anyone actually used one of the eBay radiators?
  6. dm_n_stuff
    Dec 10, 2003
    43,711
    26.806311,-81.755805
    Dave M.
    Many moons ago I considered replacing mine with one from Ron Davis but at the recommendation of my mechanic had it recored instead.
    If the Ron Davis had been an exact match, I probably would have gone with that. At the time, I don't recall that being an option, and I was trying to keep the car as original in appearance as I could.
    MarkT likes this.
  7. racerboy9
    racerboy9 F1 Rookie
    2,642
    You could also just try having the right side tank re-soldered if that is the only problem.
    MarkT likes this.
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Mark, it lasted 27 years so why not just get it recored again? You had value for money from it
    Ally rads are not the overall solution as they can corrode quicker if you get the water composition wrong.....used de-ionized water + system inhibitor / AF
    MarkT likes this.
  9. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    Having the radiator re-cored or repaired was my first thought. When I lived in DC there were many good radiator shops so I had my OEM re-cored to keep the OEM look. Now that I live up in the mountains in NC it is harder to find a radiator shop I can trust. There is one about an hour plus from me that I will call tomorrow and see if they work on more than just US radiators and if they can get the correct core. I believe that the correct core is 12 fins per inch.
    The first time I had the radiator re-cored I was all about OEM look. I have owned her since '74 so that was my state of mind. But as I got deeper into my restoration I decided that I was going to restore it to Euro specifications since I did/do not see selling it for a long time. This is why I am not as strident about keeping an OEM-look radiator and am strongly considering going with a good aftermarket radiator.
    Yesterday I confirmed that the radiator was actually leaking from the core and not the bleeder screw as I had hoped.
    Two months ago after a drive, I noticed that the bleeder was weeping so I replaced the copper washer under the knurled bleeder screw with an O-ring/ aluminum washer. This stopped the obvious leakage but a lot of antifreeze had pored out onto the right side of the radiator core so it was still wet.
    I took her for a drive and when I saw puffs of steam I thought it was from the remaining antifreeze coating the radiator from the bleeder leakage.
    This month, after a few drive cycles, I kept seeing dripping from the metal body seam under the radiators which I would dry out by stuffing paper towels under the radiator. The bleeder was not leaking so I knew I may have a real leak.
    Yesterday after a drive cycle, I put her on the rack and it was again dripping fresh antifreeze and I saw fresh green wet on the right side of the core along the header.
    Today I am going to perform a pressure test to confirm if it is the core or the header seam that is leaking.
  10. fatbillybob
    Aug 10, 2002
    28,965
    socal
    1st I assume you pressure tested to see if the core is leaking. 2n'd keep the old radiator if someone wants the original and they can core it. 3rd the other poster is right. sometimes RD radiators need some mods to core support to get them to fit. This happens often because cars need more cooling capability than they had oem. For example the radiator was just marginal in size for the BTU's needed to be shed or life in hot climates need more headroom like sitting in traffic on a 100F day. RD is known for making thicker cores to get more capacity. Our OEM rads on C5 vettes are 3/4". The RD for racing is like 2". We need that thickness to throw off lots of BTU's. The thick RD ment changes in our core support to make it fit. So one issues is what is RD going to make? Let's say you just need a little help in cooling you can sometimes stay OEM on the rad and add and oil cooler or just electric fans which wasn't a thing in 1960's.
  11. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    FBB-
    Yes, I performed a pressure test this morning and it lost 1 psi every 5 minutes starting at 13.5 psi (.9 bar). No big drips on the right side head/core seam since the motor was cool but I did see a wet sheen. So it leaks at the right side by the header tank.
    I agree and am concerned about how much cooling capacity I could lose going to an aluminum core if it is dimensionally duplicated and has the same fins per square inch as the OEM. My re-core worked very well for many years even in traffic, holding about 185-190 F and not kicking the fan on. My OEM used to kick the fan on quickly at a light even with its truck's hi-density core.
    I am checking with GTO Engineering and Mark 7 to see if they are still making OEM design reproductions. If they are I will have another option retaining the OEM cooling capacity.
    I trusted the shop in DC that re-cored my rad and I had no issues installing it. They are long gone so I am stuck finding one with experience. My fear of having it re-cored by a shop that I do not have experience with is that a fraction of an inch too wide and I will not be able to install it. Concerns either way I go.
    From Jon's photo comparing the two, it looks like the RD he installed had the same core dimensions as the OEM.
    I am not sure if Jon still uses the RD radiator. The photo I saw may be the only one he fitted and now uses only re-cored OEM radiators to keep the BTU capacity. I was hoping Jon could jump in and let us know his experience with the RD radiator.
  12. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    I think I am coming to that conclusion but I do not have a local radiator shop I know I can trust just yet. On Monday I am contacting one located about an hour or so from me to get a feel of how they approach a job like this. If they sound professional I will pull the radiator and bring it down to them for a hands-on discussion. I. have nothing to lose. I am sure that most shops can find the core I have in it now. Even back then the radiator shop could not find the OEM style core so I went with the best they had.
    NYC Fred likes this.
  13. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Why not, most would never know the difference.
  14. racerboy9
    racerboy9 F1 Rookie
    2,642
    There are a few used originals on Ebay right now. One looks pretty good. I know it is a crap shoot. Maybe they could have it pressure tested before you commit.
  15. fatbillybob
    Aug 10, 2002
    28,965
    socal
    I don't see any difference copper core to Al core myself. It is the size and number of passes and other design issues. Al vs copper I don't think is an issue. I don't worry about corrosion either. Just use a quality coolant and change it on interval. Use the BMW or Zerex g48 or whatever they call it now. I use zerex G05 because it works in my diesel and I can stock one fluid for everything. Just keep types the same not colors. So OAT with OAT coolant HOAT with HOAT etc.
    Finally I have seen skilled guys weld those leaks just fine at the core to header junction with low fusing solder. I had a guy weld a junction leak on an AL 348 ferrari radiator with plastic header!
  16. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    One looks pretty good but I would have to assume that it was removed because it was leaking --"30 years on his shelf". Even if it passes a pressure test it still could be an iffy buy. I have heard that old solder hardens and can crack with stress making it a bit of a time bomb if I do not install a new core.
    The other radiator for less money looks a bit caved in by the mounting bracket.
  17. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    Well if had access to that technician I would go for a re-core. Does anyone have the part number of a core they used for their re-core?
    I did a deep dive into the debates between aluminum and copper radiators. Many debates end in a draw because even though copper conducts heat better than aluminum, the use of solder to mate to the tanks reduces its superiority. Others just take sides and cannot convince the other side. No real-world data- just opinions.
    The only real-world data on aluminum radiators I have are from guys on the Landcruiser forum who have replaced OEM radiators with aluminum replicas and have had no overheating issues going overland.
    When I started this thread asking about the currently available DR radiator, I was looking to get around the hassle of having to find a radiator shop that I could trust. Buy a new one and install it- easy way to go. Unless GTO starts making FIM reproductions again, the DR Al radiators were my only option if buying new. The Mr Fiat version does not look correct.
  18. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Most of the restorations I do I get the originals recored. On Dinos I've made for me I like using aluminum. I get them serracoated satin black and you really can't tell the difference. The Ebay one is fine and I used one of those. I did have to heat up the lower pipe and bend a little for fitment. If it werent for the naysayers I would leave it bare aluminum!
    NYC Fred and MarkT like this.
  19. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    Thanks Jon
  20. pshoejberg
    pshoejberg Formula 3
    1,818
    Denmark
    Peter H
    Get your old original unit re-cored with a newer slightly more modern & efficient copper core. Paint it all satin black and nobody will notice if there is a small difference in the matrix design. It's more costly than buying an aluminum thing but you will maintain the originality of the car and not least the value. These nice radiators should be regarded as a wear item that can be perfectly re-build. The solder and the core gets tired over time but the radiator frame can in principle live for ever.
    Best, Peter
    MarkT likes this.
