360 - Recreate Challenge Front Grill Frame | FerrariChat
360 Recreate Challenge Front Grill Frame
Discussion in '360/430' started by EastMemphis, Jun 13, 2023.
  1. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,854
    Memphis, TN
    I decided to replace my stock front grills with Challenge grills because my stock ones were beat up and had a lot of broken plastic. Challenge grills were the obvious choice so I located a pair on eBay for about $150 each. Silly me, I didn't check the part list. There's a frame required, besides the grill, to seal up the cooling duct for the radiators. (parts 39 & 40 in the diagram below)
    Checking parts online found that these frames are (naturally) ridiculously expensive. About $500+ each. Spending another $1000 on my car is of course a pleasure, but sometimes I'd rather just keep my money and do something else.
    I decided to reproduce the parts and 3D print them instead. I found one grill frame for sale on eBay for $80 that was beaten up and broken but it would serve as a model just fine. It's a large part with about 15" at the maximum dimension.
    After digitizing the dimensions and importing that data into Fusion 360, I had a solid model.
    After printing, this is what I had:
    Unfortunately, my printer is only capable of a maximum 9" dimension so this is a 60% scale model. I'm getting a much more capable printer in about a month (Prusa XL) that can print it in full dimension, in Nylon, which will be usable as a replacement part.
    I wrote an in depth article on the entire process: https://www.ferrari360.org/2023/06/ferrari-360-front-challenge-grill-frame.html
  2. GogglesPisano
    GogglesPisano F1 Rookie
    3,223
    East Bay, California
    Joe
    Nice! Ever think about getting it milled out of ABS from one of those rapid prototype companies or is it more about making it yourself? Obviously the new printer cost more than the parts but will be of greater use in the future.
  3. EastMemphis
    May 25, 2019
    1,854
    Memphis, TN
    #3 EastMemphis, Jun 13, 2023
    I was already getting the printer for other reasons (ordered it last year), so this is just another part to print. I'm kind of a do-it-myself kind of guy so I wouldn't want to send it out. Besides, if I did get it done from one of those printing companies and the part didn't fit just right, I'd have to do it again. By printing it myself, I can tweak it to make it fit nicely and not have to worry about a two week and $100+ (?) lag.
    As for milling, the geometry of this part would make it difficult to mill. I could probably do it by mounting the blank in the indexer, then doing multi-sided milling using the indexer as both the hold down and rotational platform. That works pretty well but is a pain to design. 3D printing for a part like this is the way to go. In nylon or another tough material, it would be far more resilient than the original fiberglass part, and probably lighter too.
    The original part I purchased on eBay had three of the five mounting points broken. I had the same thing on my stock grills. I think the bumper flexes pretty well when the car is bottomed out, or hits a wheel stop in a parking lot. The problem is the grill frame and the stock grill are inflexible and instead of moving, they crack. Making the frame out of a more pliable material will likely last longer and follow the motion of the bumper instead of just cracking and breaking. At least that's my theory.
    (I used a Prusa MK3S+ to print this. My new printer is the Prusa XL.)
    KC360 FL and GogglesPisano like this.
  4. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    I’ve been very impressed with your fabrication skills.
    Didn’t you make a removable hard top for a spider?
    -ray
  5. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    So am I to understand you will make the Challenge grill insert too as well as the frames?
    mb5 likes this.
  6. EastMemphis
    May 25, 2019
    1,854
    Memphis, TN
  7. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,006
    Cape Town South Afri
    Dave
    Great job , I printed a RHD Stradale lower dash and then made a mold from the print . Then made a glass fiber lower dash from the mold . Built a Voron printer to do all this . The Prusa XL is getting some great write ups
    Would you share the STL files , I would like to print a set
    EastMemphis likes this.
  8. OrmondStar
    OrmondStar Karting
    177
    Lake Mary, FL
    Richard
    Do these require the frame or are they direct replacement to stock ones?
  9. rizzo308
    rizzo308 F1 Rookie
    2,782
    Perth, Australia
    riggio
    Direct replacement will fit fine without the frame.
  10. EastMemphis
    May 25, 2019
    1,854
    Memphis, TN
    The frame is required if you want the cooling duct to be sealed. Without the frame (the grill just covers the opening), air will spill out of the cooling duct and bypass the radiators. The frame takes up about a two inch gap between the grill and the radiator ducts. While this probably doesn't matter puttering about town, I think a risk of overheating would occur if the car was driving in a sporting manner.
  11. imahorse
    imahorse F1 Rookie
    4,366
    WI
    Dustin
    I'd be interested in a set. I considered buying basic grills and modifying them to fit.
    Sent from my toilet using FerrariChat.com mobile app
  12. EastMemphis
    May 25, 2019
    1,854
    Memphis, TN
    You could cut the fins out and it would probably fit just fine. I considered that too, but my existing stock grills are in rough shape with broken attachment points. The material is very brittle too, so it can't be repaired.
  13. EastMemphis
    May 25, 2019
    1,854
    Memphis, TN
    Finally managed to print a full sized Challenge Grill Frame in nylon. It's been quite a road to figure out how to do this successfully, without warping or other issues. The biggest problem is that the part isn't flat. It needed supports and in nylon, that can be a royal pain. To solve the support problems, I searched for a combination of materials that would result in the supports being lightly held so that the entire support structure would pop off after printing leaving zero post printing work to restore the surface that would normally be heavily scarred by the supports.
    The combination: Essentium HTN and Amazon Basic PETG black. The PETG support structure sticks great to the bed sheet and the HTN sticks very well to the PETG but when cold, the PETG doesn't stick at all to nylon and just pops off. A miracle of material science! To anyone who has printed 3D before, they know what I'm talking about but to everyone else, this all sounds like Greek, or Geek.
    Essentium HTN is a high temperature nylon that will function at 200C (about 400F). No part on a car, with the exception of parts in the combustion flow path like headers and cats, ever gets near that temperature. It's an extremely strong and tough material that exceeds the original in every category except weight. The weight is about the same, around 150 grams.
    HTN sands easily and since it's not temperature sensitive, it can be worked with machine tools. This part requires no finishing since it's an internal part but for anything else, it can sanded and even polished to a high sheen, or painted with automotive quality materials and processes.
    Here is the frame in the printer. Note the support structure, the more black plastic, under the part.
    And here is the bottom of the part after it popped off the support structure. Note what's left on the printer.
    So now I have the design, the printer, and the method of printing. Now all that's left is fitting it to the car. For that, I have to take off the bumper again and for that, I need help. That will take a few days to gather.
    imahorse, mb5, Ghostdiver and 2 others like this.
  14. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,120
    Josh @jtcarprojects
    Looks amazing. My son is getting into 3d printing.
