Rectangle 355 Plug (behind Rear Shock Tower)... | FerrariChat
Discussion in '348/355' started by huzilulu, Nov 1, 2011.
  1. huzilulu
    huzilulu Formula Junior
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    Hey guys
    I am trying to remove the pins from the two rectangle plugs (12 pins each) that are at the rear drivers side shock tower in order to install the GCK...
    I have removed the yellow 'cover' on the pins (on the inner side), but am unable to get the pins loose/wire removed. Can someone give me a brief how-to for this...
  2. pyroguy
    pyroguy Formula Junior
    Dec 20, 2006
    669
    Minnesota
    Steve
    OK first I have to get my old brain to actually recall how I did it. IF you look closely there is a tiny retaining tab for each contact. This tab is part of the contact housing. I used a dental tool to bend the tab back to release the contact. I did take a few photos so I will try to dig them up and post them for you. The dental tool I used I bought at Walgreens (dental plaque scraper) Looks like a flattened dental pick. MIght not be able to post photos until next week as I will be traveling overseas tomorrow. I'll give it my best.
  3. WATSON
    23,929
    WI
  4. huzilulu
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    Wish I could get the right tools in Dubai...
    How does the locking mechanism on the plug work? If I slide in a pick from the top, will the pin release by itself/pop out, or do I need to push the wire through?
  5. pyroguy
    Dec 20, 2006
    669
    Minnesota
    Steve
    Pin pulls out of the back of the housing.
    Sorry I won't be able to access my photos right now. They are on my other laptop and I will be out of the country for the next 5 days.
  6. Gearjammer
    Gearjammer Rookie
    Aug 3, 2010
    20
    Sooke, BC
    Rod J.
