Red Bull chassis difference *SPOILER* | Page 2 | FerrariChat
Discussion in 'F1' started by skeletor123, Apr 13, 2011.
  1. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,186
    ESP
    Bas
    Whatever it is, the RB7 must be the greatest leap forward in F1 design since the F2002 (the fact that it had the radiators in a flatter angle, allowing them to significantly reduce the height of their sidepods, compared to all vertical radiator setups of all other cars, was simple yet brilliant.)...except this, as far as we know, still baffles every aero engineer's mind it seems.
    What does Newey get paid? Must be close to 10-15m EU a year?
  2. bigodino
    bigodino F1 World Champ
    13,221
    The Netherlands
    Peter den Biggelaar
    I've heard free passes to every GP and a case of Red Bull.
  3. Ney
    Ney F1 Veteran
    7,462
    Perhaps they are using some type of torsion bar system and transfering suspension loads into the wing causing it to deflect at speed. When the car is balanced and at rest, the wing would be perfectly rigid and pass all FIA tests, but while moving would deflect the wing enough for an aero advantage.
  4. d_98se
    d_98se Rookie
    Aug 11, 2004
    14
    Nairobi/Atlanta
    Am still awaiting on answer on last years Illegal Adjustable Suspension. Does anyone remember M.Webbers car bottoming out with sparks flying everywhere during P3 qualifying runs?
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,968
    Atlanta
    John!
    I don't remember it in qualifying, but I certainly remember it during the race. RB7 runs a huge amount of rake so we are definitely not seeing an rear end scraping this year.
  6. Bas
    Mar 24, 2008
    43,186
    ESP
    Bas
    car was scrutineered numerous times just to check that thing out specifically. Never found anything wrong with it, so car was deemed legal. Ferrari etc where lowering their cars as well, but was pretty obvious it happened at the pitstops.
  7. rmani
    rmani F1 Veteran
    Nov 1, 2003
    7,334
    NJ
    RMani
    Last I heard it was 10M lbs/yr. By far the highest paid engineer in the sport
  8. Ney
    Ney F1 Veteran
    7,462
  9. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
  10. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    I think that would be a flagrant violation of the rules and would not get through scrutineering.
  11. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
  12. Ney
    Ney F1 Veteran
    7,462
    I don't disagree that it would be in violation, but something is causing the wing to flex or appear to flex while the car is moving, but remain rigid (and legal) while at rest. Some sort of post tensioning cable system might accomplish that. I do not have enough knowledge to make an accusation of cheating, but a few more wings comming off of the Red Bulls might help their competitors understand how they do it. I understand that they run a greater chassis rake than the others, but it certainly appears that the wing position runs lower to the ground than what just chassis rake could account for.
  13. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Ooh, I love a good conspiracy theory ;)
    Anyone heard anything about that little "contravention"? [I guess a fine will be forthcoming? The infraction should hurt IMHO - Forget a fine, deduct points! That'll stop anyone doing it again....]
    As to the wires/cables - My guess is simple camera feeds - The FIA can put cameras in many (defined) locations, and the loom has gotta be in place for 'em. [And/or it's their own mounts of course]
    Cheers,
    Ian
  14. kraftwerk
    May 12, 2007
    26,826
    England North West
    Steve
    The thing is it could be just structured to be strong where the FIA test it only, and flexiable else where, or is that just to simple.
  15. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Got to take the fun out of it, do you? :)
  16. kraftwerk
    May 12, 2007
    26,826
    England North West
    Steve
    Radio camera's ? need no wires.
  17. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Camera is possibly linked to battery and/or transmitter.
  18. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    IIRC, that was pretty much the conclusion "we" reached - The FIA loads the wing ~12" (?) (300mm in new money ;)) from the centerline - Just outboard of the mounts - RB have figured a way to make "flexi-carbon" that bends under aero load, but only outside of the test points.
    The others are no doubt sitting in front of their 'puters trying to figure out how to do it......
    Cheers,
    Ian
  19. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    +1
    IIRC, deep in the technical regs the entire thing is spec'd - Certain type of connector, power, gnd, signal etc pins are all specified. Then the teams hook in their own recorders/transmitters - Some of the shots looking at the tea tray for example have gotta be *very* revealing.....
    Cheers,
    Ian
  20. Ferraripilot
    May 10, 2006
    17,968
    Atlanta
    John!
    I heard the other day that immediately following the crash, everyone had all eyes on the Red Bull front end and wires and every one of the teams requested the RB be reviewed immediately. Charlie Whiting literally ran to the RB pit prior to the car arriving and inspected things. Nothing has been disclosed regarding his inspection yet.
  21. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Charlie was on scene and the wall wasn't taken down? To be fair he may have just not noticed ;)
  22. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Actually, I suspect that's the reason for the modesty screen - They have a right to privacy if the FIA are poking around.
    Very interested to hear what Charlie has to say - If anything.....
    Cheers,
    Ian
  23. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    You're poking all of my balloons today ;)
  24. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Sorry dude :)
    I'll keep off your lawn, I promise ;)
